I am not sure if this is the right place to ask but does anyone have any particular recommendations for a good astronomy monocular?
Posted 22 December 2022 - 06:22 PM
Posted 22 December 2022 - 06:42 PM
Do they even make such a thing? Most monoculars in the binocular world are junk, the internet is awash in them at about $20-$40. There are high quality units from Zeiss and Leitz, but they are too aperture-limited for astronomy. Beyond that, you end up in spotting scopes. Celestron's Hummingbird 50mm spotter is tiny and from most accounts, provides very good image quality. They make a 50mm and 56mm version.
https://www.atlantic...NRrM6fJ5sByy5dU
Posted 22 December 2022 - 07:47 PM
I have a Hawke Endurance ED 8x42 that's not bad for the night sky. It's even got a tripod mounting hole on the bottom of it. I've spent a few hours with it after dark. It does ok.
Posted 22 December 2022 - 08:17 PM
Thanks, I'll check it out!
Posted 22 December 2022 - 08:40 PM
Look at the Gosky offerings. I have the 10x50 and it's very good in both optical and build quality. There are several other models. Some have ED glass too
https://www.amazon.c...e904010ad0&th=1.
Posted 22 December 2022 - 08:43 PM
Thanks will check those out too. Probably going to try and grab something during the boxing day sales.
Posted 22 December 2022 - 08:57 PM
Edit: I just looked at the OP’s footer and see that they already have an 80mm apo so I’ll address my comment to others who may not have a telescope and just have binoculars.
I always say, the best monocular for astronomy is a telescope. Just get a nice, small, shortish refractor. A scope with ED optics is preferable but you can have an awful lot of fun with a simple achromat like the ST80. Want to spend a bit more and get some real quality, then think about an AT72EDII from our sponsor (Astronomics); you’ll get a 5 pound scope with an F6 FPL-53 and Lanthanum-mated doublet objective. Getting a real scope will give you expandability and versatility you will never find in a monocular (or even a spotting scope).
https://www.astronom...fpl-53-f-6.html
https://www.telescop...2160/p/9946.uts
Edited by Terra Nova, 22 December 2022 - 09:00 PM.
Posted 22 December 2022 - 09:11 PM
The Gosky 10x50 monocular was on an Amazon Flash Sale when I bought it. For $70 I figured it was worth the risk. Very pleasantly surprised The armored scope fits nicely in your hand with an index finger focuser. The optical coatings look good to me and it's even waterproof. There's a 1/4-20 thread so it can be mounted on a monopod or tripod. There's even a decent soft case and a padded hand strap. Do I sound like a salesman...you bet I was
Posted 22 December 2022 - 09:18 PM
Doesn't fit in a pocket very well.
Posted 22 December 2022 - 09:37 PM
Neither does half of an 8x50 binocular, unless you have big pockets.
Posted 22 December 2022 - 09:40 PM
Yah, the main reason I want one is something ultra portable I can just throw in a jacket and use anywhere. If I want to take images or do detailed visual on a mount I've already got all the gear for that.
Posted 22 December 2022 - 09:42 PM
I have a few monoculars. It isn't exclusively for astronomy but it is useful you want to see something
when naked eye isn't enough to see.
I used to carry Nikon 5x15 but I upgraded to Goto 5x18, aperture fever
Tammy
Posted 22 December 2022 - 09:59 PM
I would not go any higher than 8x. Monoculars are a lot harder to hold still than binoculars. Simply because you don't have as many "contact points" with your face and forehead to help stabilize them.
Posted 22 December 2022 - 10:00 PM
And consider a monopod. A lightweight monopod works wonders for stability. Even just a stick can help.
Posted 22 December 2022 - 10:41 PM
Bought these on coupon sale at Harbor Freight 10 years ago.
Posted 22 December 2022 - 11:17 PM
The SVbony 8x32 and 10x32 ED Monoculars get lots of good mention in this thread: https://www.cloudyni...r#entry11995450
I own one of the 10x32 ED models and it was so much better than my Orion 10x42 monocular, I sold my Orion!!
Posted 22 December 2022 - 11:37 PM
Thanks. I've actually had pretty good luck with Svbony gear so far.
Seriously thinking about this one right now:
https://www.amazon.c...r,aps,82&sr=8-7
Posted 23 December 2022 - 11:25 AM
That is the model I own. I consider it pretty good in the size / performance ratio. You can save $50 over amazon by buying it direct from svbony: https://www.svbony.com/sv36/#F9329D
Posted 23 December 2022 - 11:44 AM
lancing...In my experience, any optic good for night sky viewing needs a large objective to gather enough light. It also needs enough power to magnify the small objects. A small shirt pocket monocular with a small objective will be fine for daytime...not so hot at night. Your original post asked about an astronomy monocular?
Posted 23 December 2022 - 11:54 AM
I guess the closest thing I’ve come to that was my Stellarvue Little Rascal 50 mm RACI scope.
Posted 23 December 2022 - 12:20 PM
Yup, ideally something portable I can take out that would enhance my ability to see in the night sky if I happen to be going out for a walk or something.
I don't need anything larger as I already have an 8" SCT and 80mm refractor.
Posted 23 December 2022 - 12:35 PM
Pretty much. You can't see anything of planets with a hand-held 8-10x scope and objectives of 50mm or below really don't show much in the way of deepsky objects except maybe some larger open clusters under dark skies. That leaves the moon and the sun. Monoculars are mainly for terrestrial objects.
Posted 23 December 2022 - 03:05 PM
I use the Gosky 10x50 monocular at night when I'm guiding my Dob with it's laser finder. It's very useful that way
What is a monocular? A telescope. When you're small they call you "monocular"....AFAIK these are apo refractors
The optics on the 5x15 Nikon one are very nice.
Edited by Scott99, 23 December 2022 - 03:05 PM.
Posted 23 December 2022 - 07:11 PM
You want something small enough for your pocket - I get it. I have the Orion 8x25 ED monocular and it is really good, with of course its small objective lens. It costs about $100. I keep it on a neck lanyard but it easily fits in a shirt pocket. Its end caps are the same size on both ends - a bonus. I also have an old Zeiss 8x30 B monocular that I had professionally cleaned on the inside, to eliminate a slight yellow haze. The Orion is almost as good as the Zeiss. The Orion is a cylinder shape and is perfect for your pocket. If you go up to something in the 30 mm range or bigger, it will obviously not fit in a pocket as well as this Orion. Due to its shape, I recommend the Orion over the Zeiss.
I have a few other monoculars including one that is Japanese made and is 8x24. The Orion is much better than that one even with only one mm more of objective lens. Obviously better coatings. The Orion gives me a brighter view of the night sky.
For its small size, I am very happy with the views looking at the night sky. You already have other bigger optics. This is one you will like having in your pocket. Far better than just looking up while taking a walk, with no optic.
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
