I've been out observing a few more days and nights with the scope and I am really pleased. Friday night I observed Comet C/2022 E3 (ZTF) and Mars in the same field of view and it was a very memorable view with the comet displaying a faint tail as it slowly drifted by an ~9th magnitude star near the nucleus. I always enjoy when close field stars make observing cometary motion easy!
I have not totally worked out the balance conundrum, but I have moved the rear ring forward on the dovetail and removed the finder bracket from the focuser and it has allowed me to relieve some tension on the altitude clutch so things are operating just that much smoother.
Also angling the focuser knobs on the right hand side up just a little has provided all the clearance needed for easy operation without the SV handle interfering.
Earlier I mentioned that I had purchased an Innorel carbon fiber tripod off Amazon. It is a good match for this system, and the perfectionist in me did note that under high power at night or zooming in on a sunspot, I would have a little vibration induced when focusing - it didn't ultimately prevent accurate focus, but I'm used to my rock steady set up with the TEC 160, so my standard is unfortunately vibration free. Another CN member sent me a private message, the same one who first recommended the tripod and also has a SV MC2 mount, and shared a trick that had been shared with him. Acquiring some (automotive) gasket material from Amazon, I cut a circular piece to sit between the mount and tripod - and I was pleasantly surprised that it did eliminate much of the small vibration (which was already pretty minimal). You can see this gray colored gasket in the picture below. I'm not marketing this as a wonder material, but as the vibration was already minimal, just placing a different material between the metal tripod and metal mount seems to have made just enough of a difference.
Another revelation was that I can live, easily, without using my 2" eyepieces on this scope. This relieves me of changing tension when changing between 2" and 1.25" eyepieces. The 24mm Panoptic gives up nothing other than FOV to my 28mm AT UWA...and my 21 Ethos is just too heavy to drop into the back end, despite the amazing views. From the 24mm Pan (23x/2.9 deg FOV), I am most likely dropping right down to my 10mm Delos (56x/1.3 deg FOV) which is a 1.25" eyepiece. I have been mulling over the idea of getting a 1.25" diagonal to further aid with balance, but I've spent a bundle on this rig already...so need to really decide before I just act to try it out....any reasons why not to get a 1.25" diagonal?
Now that I'm free from 2" eyepieces, besides considering a 1.25 diagonal, I am likely to go the route of the Baader click lock visual back...anyway, here is the pic of the night configuration, as it is in final form (unless I change diagonal and visual back
Clear skies,
