I got my AT80EDL today serial #40. I used it tonight but got run off by clouds it was a short session. I can see what ya'll are saying about the balance, I will have to play with mine in the tube rings. Luckily the tension on the M2C I can find a sweet spot that holds the scope fine.
I only have 3 eyepieces at the moment... Pentax 23,16.5 and 7 XWs as I sorta was in a transition from APM XWAs to Pentax XWs. I just sold some more stuff so I am going to place an order for another XW tmrw... most likely the 10mm which I think will get a lot of use in this scope and will be a good planetary eyepiece for the C11.
A few thoughts about the scope... well I knew what I was getting cause I've had the AT 72EDT II, 102EDL and 115EDT. No offense to the 72 fans but it just always kept me wanting more aperture - in spite of it being a one hand out the door scope. 80mm is just perfect for GnG for me.
Well, I've always had issues with field curvature for my eyes with short FL refractors but the 23 Pentax seems like my eyes can accommodate and I can get a good focused image with this scope in the eyepiece. So I could be happy with this as sorta widest field of view 2" eyepiece for "my eyes". I haven't crunched numbers but its probably something over 3 TFOV. I eventually want to get a 40XW for my C11 and I probably will try it in the 80EDL - maybe just large nebula with a filter will be good?
I looked at a few DSO... Double Cluster - Orion Nebula - Caroline's Rose - split the double star in Gemini either Castor or Pollux I forget which is which. It was pretty much just a test run cause like "clouds".
Some thoughts on the viewing... double cluster looked great in the 16.5mm... there is a group of stars that look like a trapezium between the two main clusters and I can see all 4 stars one of them is really dim (In an 80mm scope) but it's there so I was pleased. One of the stars is orange\yellow and you can see the color too which is also great. The 7mm is a bit too much power for this DSO so I think the 10mm will be my next EP.
M42 was impressive with the 7mm - the trapezium was easily seen and split - I could swear I could see one of either the E or F stars blinking in and out.
Carolines Rose was nice in the 16.5mm you could see some resolving of stars it was faint but present. The 7mm was just too much for this target in my sky.
I had a really nice clean split of double star in Gemini.
Anyway love the scope and eyepieces. I'm going to get that cheap case in this thread and use the foam from the packing and maybe over the summer try and grab a smaller\tripod\mount for it but it's still easy setup on my M2C.
cheers
Kristian
