Goofi's Imaging Challenge, January 2023 - NGC 2403
28 replies to this topic
#1 nikm
nikm
  • Loc: Wenatchee Valley, WA
Posted 03 January 2023 - 11:44 AM
The January 2023 Challenge is now open. The target is the NGC 2403. To reduce the number of stickies, please submit your entry to this thread.
The Rules will remain pretty simple:
-Your Equipment
-Your Data, Captured This Season
-Your Processing
-One Entry Per Member
-Only post your FINAL image. Please display an image in your post, not just a link!!
NO general discussion in this thread. Your post should only contain your image and appropriate info. There is a separate thread for discussion.
To increase participation over such a diverse group, the winner will be selected by random drawing.
Entries must be submitted by midnight, eastern time, on January 31, and I will try to announce the winner sometime after February 1.
If the selected winner does not reply and pick a target with-in 3 days of the winner being announced, the Mods will then select the next target.
There is now a companion thread that runs parallel with the imaging challenge each month. This thread will be for general discussion on the corresponding months imaging challenge target. This thread will be very informal and relaxed and will be treated just like any other thread in the forums. Here is where you can post questions on processing, get help finding the targets location, post a preliminary "final" image to get feedback, etc. The only thing special is that I will be pinning it every month and each months companion thread will be titled in the same way for easy finding and searching. Since this is informal the mods will NOT be starting this thread. We will leave it up to the general membership. So it could take a couple days for someone to start it and for a mod to pin it. So please be patient if you don't see it up day one. Who ever starts this thread please PM me with a link to the thread so I can pin it.
Whoever starts the companion thread should title it to match the following: Target Name - Techniques and Progress Discussion  For example: Rosette Challenge - Techniques and Progress Discussion
Once the companion thread is post, please DM me with a link and I will get it pinned.
Note: If I am late announcing, gently nudge one of the moderators in a private note, it helps.
I hope everyone has fun with this one, and with that,
Let The Games Begin
#2 TomC_RR
TomC_RR
  • Loc: Southern Oregon
Posted 11 January 2023 - 02:58 PM
NGC 2403 taken Jan 9 2023.
Canon T7
on AT130EDT with .8 reducer/flattener with Teleview X2 powermate. - first time try with this combo.
on SW EQ6-R-Pro
with AA+
Processing started as a fail - but I continued without being able to calibrate with bias / darks / flats. I will be starting a new topic to ask question on what happened.
30 x 240 secs @ 3200 ISO
30 X 300 sec @ 3200 ISO
Stacked in PI ImageIntegration because WBPP failed - but did leave me with debayered & registered images
Channel extraction
Linear Fit
Channel combination
ABE
BXT
EZ Denoise
Curve Transformation
Histogram Transformation
Southern Oregon weather looks like this may be my only shot this month.
Ngc 2403
#3 unimatrix0
unimatrix0
Posted 12 January 2023 - 09:18 AM
Ok, so I'll post it, since I'm away next week and I won't get the chance to image much more, plus the weather is all over the place anyway.
EQ6R pro mount
RC 6 telescope + CCDT67 reducer set at 972mm reduction
ASI533mm pro + 1.25" ZWO LRGBHa filters
N.I.N.A imaging
Acquisition dates:  12/20/2022 thru- 1/07/2023
get.jpg?insecure
#4 Kring
Kring
Posted 15 January 2023 - 03:44 PM
Sharing my NGC2403 for my first challenge submission. Taken two weeks ago and just got around to processing.
Imaged with Celestron EdgeHD 11”, 0.7x reducer, ASI2600MC, ASIAIR, CGX Mount.
37 x 300sec exposures over two nights, sensor temp at -20C.  Captured flats, dark-flats, used my existing bias & darks to calibrate.
PixInsight Blink - I don’t recall exactly how many I blinked out, was probably around 5.
PixInsight processing WBPP, BXT, NXT, SPCC, histogram stretch, tweak histogram, boost saturation to final data, save at TIF.
Load into Photoshop just to crop then convert the TIF to a high quality JPG at a little smaller size.
Final image processing done in Apple Photo app on iPad - use the auto adjust then pull back brightness, vibrance, saturation and lower black point to give final look.
Edited by Kring, 16 January 2023 - 11:52 AM.
#5 Old Photons
Old Photons
  • Loc: Ontario, Canada
Posted 15 January 2023 - 05:32 PM
Below is my NGC2403 for the January 2023 challenge.  Details are:
-Askar 107PHQ, unreduced
-HEQ5 Mount
-ZWO ASI2600MC; 77x300" 0 Gain
-Captured 22-11-06
-Reprocessed in Pixinsight 23-01-14 to apply SPCC and Blur Xterminator
#6 southernharry
southernharry
  • Loc: Woodstock, GA
Posted 16 January 2023 - 11:25 AM
Beginners' entry-
AT 102ED @ 714mm, ASI 183MC, UV/IR Filter, CEM26 Mount
3 Hours - 60 sec x 180 on 1/15/2023.  B6/7 skies - or worse in my yard.
APP, AP, PS Elements for processing
#7 Apennine
Apennine
Posted 16 January 2023 - 12:48 PM
Hi Everyone,
Here is my entry:
- Full details on Astrobin, if you click the image
- ED80T CF, CEM-40/ZWO AM5, ASI294MM run by N.I.N.A.
- Imaged over the last week (12h 56' HaLRGB)
- Processing (Pixinsight)
  • Crop
  • DBE
  • RGB Combine
    • SPCC
    • Add Ha via Pixel Math
    • Histogram and curve transform to RGB
    • Convolute RGB
  • Lum
    • BXT
    • NXT
    • Histogram Transform and Curve Transform
  • LRGB Combine
    • Range Mask
    • Histogram Equalization
    • MLT
Comments welcome, thanks!
-Chris
get.jpg?insecure
Edited by Apennine, 16 January 2023 - 12:56 PM.
#8 ZepHead
ZepHead
  • Loc: Schenectady, NY
Posted 16 January 2023 - 10:28 PM
Here is my entry for NGC 2403 taken on 1/15/23
Celestron Evolution 8" SCT with HyperStar on SkyWatcher EQ6-R Pro
ASI533MC, Optolong L-Pro
NINA used to take 50x120s exposures, dark, flats and dark flats
Processed in PixInsight (WBPP, SPCC, BXT, NXT)
Photoshop to crop and save as JPG
#9 osbourne one-nil
osbourne one-nil
  • Loc: Cumbria, England 54.5ºN 2.5ºW
Posted 17 January 2023 - 06:24 AM
Taken last night, when it was cold (-9ºC) still and moonless, so I figured I'd remove the reducer and shoot at my SD81's native 625mm f/7.7. It seemed to balance getting detail with a nice wide shot to give it context. I rather like it.
This is 37x180" using an ASI2600MC Pro, stacked in Deep Sky Stacker, DBE and Photometric Colour Calibration in Pixinsight and some Denoise in Photoshop.
#10 larryjh
larryjh
  • Loc: Lewes, DE, USA
Posted 17 January 2023 - 11:27 AM
Here is my entry for the month:
Data captured on 1/15/2023
Equipment: CEM26, Omni XLT 150, Explore Scientific HR coma corrector, ASI294MC pro, WO Uniguide 32, ASI224MC guide camera
264x120", gain 120, offset 10, temp -10C, UV/IR
Captured in NINA, processed in Siril, Gimp, FastStone
Seeing was poor/bad and lots of wind.
click for larger
NGC 2403
#11 Beaverpond Astro
Beaverpond Astro
  • Loc: Perth, Ontario
Posted 19 January 2023 - 10:08 PM
I think I've messed with this image enough...time to just post it!
Taken with a RASA 11:  OSC+Luminance+Ha
The OSC data was taken with a 2600MC;  the Luminance was with a 2600MM and Astronomik L2 filter;  the Ha was taken with a 2600MM and Astronomik Ha filter.
Cameras were set at -10C and gain100 for both.
Data was collected over multiple nights in January, 2023.
Ha Data:  120 secs x 91
Lum data: 60 secs x 60
OSC data: 60 secs x 429
Should have reversed the number of subs taken for OSC vs. Luminance tongue2.gif.
All pre & post in PI.  Processes included: BXT, NXT, SXT, HT, various masks, curves, a little bit of saturation.
Simple Ha combination with LRGB, per a process outlined by VisibleDark (Shawn).  Ha data used as a mask on LRGB image; Ha then added via PM to the LRGB. I went light on the Ha addition...didn't want it to overwhelm the image.
Astrobin version: https://www.astrobin.com/zvnxtw/C/
Edited by Beaverpond Astro, 19 January 2023 - 10:16 PM.
#12 hollo
hollo
  • Loc: Hertfordshire, UK
Posted 20 January 2023 - 02:55 PM
get.jpg?insecure
Acquisition
EQ6R
RC8 scope
ASI2600 with ZWO RGB filters + OAG
5 1/2 hours of 60s exposures.
Bortle 7
Processing
Pixinsight (with NoiseXTerminator and StarXTerminator)
I didn't really do anything special - every time I tried to it ended up looking overprocessed. I had versions with Deconvolution, multiscale processing processes, etc., and in the end all I did was calibration, stretch, star separation, noise reduction, and a little bit of sharpening.
Notes
I'd intended to use a reducer and shoot at about 1000 f/l, but was getting really bad vignetting so shot a the native focal length instead. I also managed to rotate the camera by 90 degrees between the two nights of acquisition and so had to crop in a bit further to get to good data.
#13 Robert7980
Robert7980
  • Loc: Western North Carolina
Posted 21 January 2023 - 12:37 AM
NGC-2403 captured 1/19/23
I had a hard time with this one, went through many iterations in post processing, in the end I just left if basic.
6.75 hours total integration.
Ha LRGB.
ASI-2600MM pro.
Antlia pro 2" LRGB, Antlia Pro 2" 3nm Ha.
SVBoney SV550 80mm APO at 483mm.
Skywatcher EQ6-R.
ASI120MM, ZWO OAG-L.
Captured in N.I.N.A and processed in PixInsight, BX, stretching and curves, LRGB Combine and Pixel math to combine the Ha data.
get.jpg?insecure
Edited by Robert7980, 21 January 2023 - 12:38 AM.
#14 const
const
  • Loc: Las Vegas, NV
Posted 23 January 2023 - 02:17 AM
Collected over several nights, Jan 6–22. Bortle 9 sky, mostly without Moon.
Celestron Edge HD 8" on AVX, OAG.
ZWO EAF 5V, EFW 7×36mm, ASI2600MM Pro & ASI432MM (guiding).
Astronomik Deep Sky RGB and MaxFR Ha 6nm filters.
Captured with KStars/Ekos. Processed in PixInsight.
R 186×60s
G 211×60s
B 164×60s
H 114×120s
#15 rkelley61
rkelley61
  • Loc: Blacksburg Virginia
Posted 23 January 2023 - 09:46 PM
The weather hasn't cooperated this month, only one night with poor seeing when I captured the Ha images.  The RGB images are from October.
GSO 10" Newt / ASI1600MM Pro / RGB
ES127 / ASI2600MM Pro / Ha
G11T
Astronomik Blue 1.25" 90×120″ (3h) (gain: 139.00) 0°C bin 1×1
Astronomik Green 1.25" 93×120″ (3h 6′) (gain: 139.00) 0°C bin 1×1
Astronomik Red 1.25" 115×120″ (3h 50′) (gain: 139.00) 0°C bin 1×1
ZWO Ha 7nm 36mm 132×120″ (4h 24′) (gain: 100.00) -10°C bin 1×1
Capture in SGP, processed in PixInsight
First time combining images from different scopes/cameras which turned out to be easy (in this case) and combining Ha/RGB which wasn't so easy.  The discussion in the technical discussion thread was very helpful.
#16 CorralesRay
CorralesRay
Posted 24 January 2023 - 07:46 PM
Here is my post, image details as follows:
R: 65 subs, 120s
G: 68 subs, 120s and some 180s due to operator error
B: 51 subs, 120s
L: 459 subs, 60s
Ha: 50 subs, 240s and some 480s subs due to operator error
Mount: EQ-6R pro
Imaging Camera: ZWO ASI 2600mm
Scope: PrimaLuce Labs 104m,. F6.5 triplet refractor, with X1 flattener
Imaging Control: NINA
Post Processing: PixInsight with add ons
Processing: (I hope this isn't too much)
WBPP with flats, darks and dark flats
Dynamic Crop
DBE
Channel Combine (RGB)
Plate Solve (RGB)
SPCC (RGB)
Decon (not BlurX) for RGB, Lum, Ha
NXT noiseX
HT stretch (RGB, Lum, Ha)
Ha_Lum combine
Ha_Lum StarX  (did not save stars)
RGB + Ha_Lum combine
RGB_Ha_Lum StarX (saved unscreened stars)
HDMRT on copy of RGB_Ha_Lum
blend with original RGB_Ha_Lum
LHE (kernel radius 20)
LHE (kernel radius 50)
Sharpen with MMT
Add stars back with unscreen stars (used Lukomatico's scripts)
I am pleased with this image (perhaps ignorance is bliss), but I'm happy with the star colors and star balance with galaxy. I'm also pleased that several of the distance galaxies are visible. With more data this image would really improve. (But I was lucky to get 3 clear nights with a small moon and the clouds have moved in.)
Here is a link to a slightly larger image is one is interested: https://astrob.in/5ap1t6/0/
Ray
#17 Dedodso
Dedodso
  • Loc: Wentzville missouri
Posted 25 January 2023 - 09:03 PM
    Got this image on 1-20-2023 ,took lot of 10sec subs but a lot of them were in cloud cover and ended up with 1227 usable subs. Seemed slightly  foggy early on then everyPS3 PIX 2 SEQ_NG_2403_1_20_2023_1203_pics_800iso_DBE.jpg thing iced over.
      3 hrs 20 minutes exposure time
      Scope: Skywatcher 200mm by 1200mm flextube reflector on Alt-Az goto mount using synscan pro app on Ipad
      Camera: Canon 2000D Modded full spectrum using Backyard EOS
      Processing: Sequator and Photoshop 6.
#18 LeoNim
LeoNim
  • Loc: San Antonio
Posted 27 January 2023 - 07:50 PM
Here's mine. I've been using this to troubleshoot a reflection within the 115, which explains why there's so many L lights.
ASI2600MM Pro
AT115EDT
EQ6-R Pro
  • Antlia Blue: 13×180″( 39′) (gain: 100.00) -10°C bin 1×1
  • Antlia Green: 17×180″( 51′) (gain: 100.00) -10°C bin 1×1
  • Antlia Luminance: 367×180″(18h 21′) (gain: 100.00) -10°C bin 1×1
  • Antlia Red: 20×180″(1h) (gain: 100.00) -10°C bin 1×1
Processed in Pixinsight
  • DBE
  • Channel Combination
  • SPCC
  • BXT
  • Pixelmath Stretch
  • LRGB Combination
  • SXT
  • Curves to adjust saturation
  • Pixelmath combine stars back in
  • NXT
Edited by LeoNim, 27 January 2023 - 07:51 PM.
#19 Buzz135
Buzz135
  • Loc: Woodbury, MN
Posted 28 January 2023 - 08:59 PM
I held out for a 2nd night of data as long as I could.  Haven't had a good, clear night up here in Minnesota since early December when I took this photo.
Equipment:
- AT-115EDT with ASTRO-TECH 0.8X REDUCER/FIELD FLATTENER (version 2)
- iOptron CEM40
- ZWO ASI2600MC Pro with an Optolong L-Pro filter
- Guiding: WO Uniguide with a ZWO ASI290MM mini
- Software:  NINA and PHD2
Data:
- 120x 60sec subs
- 12/3/2022
- Bortle 7 MN backyard; Moon 80%
- Processed with Pixinsight
Buzz
#20 Chrisofweden
Chrisofweden
  • Loc: Västmanland Sweden
Posted 29 January 2023 - 02:03 PM
NGC2403 January 2023
My entry for January captured on the one clear sky opportunity I had this month!
Captured:
25/1 under Bortle 4 sky, Outside temperature: -5 Deg C, Seeing: Good (1.9)
Scope: Askar FRA600 quintuplet refractor (600mm, F5.6)
Imaging camera: ASI 2600MM Pro @-10c, Gain 100
Guiding and Dither: ZWO F4 scope + ASI 120 MC Pro
Focus: ASI EAF
Filters: ASI EFW HaRGB
Mount: EQ6R Pro
Control: ASIair Plus
Integration: 8hrs comprising 120 x 60s each with R,G & B plus 40 x 180s Ha.
Calibration: Bias, Darks, Flats
Software/Processing in PixInsight:
Blink
WBPP, separating each filter
Crop
ABE, DBE, BN
Decon
Photometric CC
LinearFit
Channel Combination (RGB)
GHS
RC NoiseXterminator
RC StarXterminator
MLT
Morph
HT
Local Histogram
GAME
Curves, Color Saturation
HaRGB Combination using Bill Blanshan advanced HaRGB tool in galaxy mode
/Chris
Edited by Chrisofweden, 29 January 2023 - 03:26 PM.
#21 TelescopeGreg
TelescopeGreg
  • Loc: Auburn, California, USA
Posted 29 January 2023 - 05:04 PM
Ok!  So an unexpected lesson learned here...  As I've told others, if nothing else this is a hobby of a bazillion little details.  When something's not working, STOP and look at what the system is telling you.  You may learn something.  Yep!
I was having huge problems focusing, and was blaming it on the rather heavy dew we were having.  But the autofocuser was showing me an unusually shaped focus curve, which I should have investigated before wasting several nights of potential imaging time.  Long story short, the focuser had hit what it thought was the end of travel, when in fact it was still in the middle.  Simple fix to reset the counter, and all was well after that.
So, this is 1.5hrs worth, still a bit of dew but an otherwise normal session.  Cute little galaxy.  Data was stacked with ASTAP and processed in StarTools.  I pushed the details a bit, using a combination of HDR and Entropy Sharpening, trying to show the structure of the galaxy without overdoing it too much.
Imaged at home on 1/24/2023 (Bortle-6+).  Transparency was good, Seeing not so.  Guiding was better than average, due primarily to the high declination angle.  Ambient temp at minus a couple of degrees C.
Telescope:  Stellarvue SVA130EDT, 130mm f/7
Camera:  ASI2600MC-Pro.  Gain 100, Temp -5C, offset 50.  No filters.
Mount:  Celestron AVX
Guider:  ZWO 60mm f/4.6 scope, ASI174mm Mini camera.  CCDciel internal guider software
Exposures:  18 x 300 seconds Lights, 20 each Darks, Flats, Dark-Flats
Acquisition software:  CCDciel on Raspberry Pi 4B with Astroberry distro
Stacked in ASTAP, processed in StarTools 1.7
#22 Alrakis
Alrakis
  • Loc: North Carolina
Posted 30 January 2023 - 10:55 AM
Here is my attempt for the month. Feeling better about the setup, but still have more to learn. I did capture more data on an alternate day with a filter, but couldn't get the two sets of data to play well with each other. Will work on that some more for learning.
Imaged at a somewhat darker site than my home on 20Jan2023 (Bortle of ~4).  The sky was very clear with excellent transparency, but the seeing was horrible and the twilight seemed to go on forever (or Raleigh was having a big party). Also, by the end of the evening the cold was a bit much (mid to low 30sF). I actually was able to get a really good image of M31 and M42 with this setup on the same night so it actually turned out well for focusing and all. I was able to have both an imaging setup and visual setup going at the same time so I could see Comet 2022 E3 ZTF (and other objects) before closing down for the night. Also, I am sure I could get more out of the data in post with more experience and time.
Telescope: Vixen R200SS 200mm F/4 (reduced to f/3 (600mm FL) with a Starizona Nexus Coma Corrector/Reducer)
Camera:  unmodded Nikon D7200 at ISO200
Guider:  Lacerta MGEN 3 (the MGEN provided the signaling for light exposures and dithered as well.)
Lights:  50 x 90 seconds (with 1 second mirror lockup)
Other: 32 Dark Bias, Darks, Flats
Pre-processed, stacked, and post in Siril
Please PM me if you have any advice on how to do this better.
Chris
#23 ntph
ntph
  • Loc: Sudbury, ON
Posted 30 January 2023 - 09:02 PM
AP130 mm with flattener, iOptron CEM70, QHY268M, filters as below
Bortle 6 cackyard
Lum 90 min
RGB 25 min each
Ha 50 min
darks, flats, bias
NINA for capture, PI for processing
WBPP, ABE or DBE, SPCC for RGB, BXT, NXT, GHS, Curves for contrast and saturation to taste
Blanshan's Ha to RGB P{ixelMath in Galaxy mode, parameters adjusted to taste.
#24 David Boulanger
David Boulanger
  • Loc: Naples, Florida
Posted 31 January 2023 - 05:37 PM
NGC 2403
14 hrs. of 2 minute subs
RC 6 @ F9 with a Orion G26 OSC at 1 degree Celsius
Bortle 7/8
APP and Affinity for post work.
Edited by David Boulanger, 31 January 2023 - 05:40 PM.
#25 hornjs
hornjs
  • Loc: Billings, MT
Posted 01 February 2023 - 12:58 AM
I was hoping to make a couple more adjustments to this before midnight (less blue), but stuck at work away from the processing rig so I'll just submit it anyway.
Edge8HD, 0.7reducer
Eq6rpro
294mm pro, -20c
Zwo asi air plus. Zwo eaf, efw
Antlia LRGB filters
L 5hrs of 120sec, RGB 180secx3x30 all gain 121 bin2
Ha 4hrs of 180sec, 200 gain, bin 2
Total Integration 13.5hr
Processed in Pixinsight.  Used Bill Blanshan Ha blend scripts - thanks Bill!
