Star Testing
I chose to do daytime artificial star testing as I've found that if I carefully choose my day, I can get truly excellent results. I typically choose overcast days (to minimize solar ground heating) with mild/no wind (a very gentle breeze actually helps) and very stable temperatures. I use a 100 micron star placed ~210' away which gives an ~.33 arc second size. I also use 2x and 3x barlows on the 1.25" nosepiece of the star to further reduce it in size (but also brightness).
I did two rounds of testing. For the first round, I took the OTA from my 68 degree F basement to the 32 degree F outdoors (which stayed there for four hours). I wanted to also judge its thermal performance. I did not use any barlows on the artificial star....forgot to really. Well, the objective, like the last one I had, was a thermal mess for a couple of hours showing heavy undercorrection (sharp rings inside of focus, mush outside of focus) and "text book" tube currents. But, at 350x, no astigmatism and the jury was out on any coma. I saw what looked like coma when moving very slightly inside of focus, but none really at focus. I have been fooled and tricked by tube currents before as they can, tome, mimic astigmatism away from focus and coma at focus. Things started settling out at the three hour mark, when I saw no signs of astigmatism. There was, maybe, scant coma at focus at powers up to 400x as a local slight thinning & dimming of the first at focus diffraction ring on one side of the image and a mild thickening & brightening of on the opposite side. The airy disk though seemed completely round, sharp and color free. The image looked really good though and really pretty calm with excellent "seeing". I was really pleased.
However, I became concerned that, even though at ~.33", and ~ 1/2 the resolution of the aperture (~.66"), it was not a true point source and may have affected what I was seeing. So a few days later, I repeated the testing, with even better ambient conditions (steady 60 degree F), and using 2x & 3x barlows on the star. Boy (!) the warmer ambient temperature really made a huge difference in how quickly the objective settled out. I could quickly use powers of 350X and later up to 600X with what I would call Pickering 9+ "seeing". Other than the obvious brightness difference, I did not see much difference between using the star at .33" or with the 3x barlow, except, with the barlow, the airy disk looked slightly smaller and there was no second diffraction ring visible at focus, both of which are probably related to the reduced brightness of the star. And man, did it look good with no hint of astigmatism and, again, maybe, a bit of "transient" coma at 400x and 600x, which was just not visible at 350X.
I also used my cell phone to capture some crude shots of the star test at 350X, at focus. They are single frame, heavily cropped with some noise, (the live visual view was sooo much better, beautiful actually) but they tell the story. Image Fa was taken without the barlow, the other two with the 3X barlow as you see in the pictures.
Jeff
Edited by Jeff B, 08 January 2023 - 01:32 PM.
