Why can't the heater be the first line of defense? Or maybe the only line of defense in at least some circumstances?
Will it simply not work at all without a shield? Or does it introduce other problems that a shield alone would not?
Hi, and welcome to Cloudy Nights!
To understand the answer, it helps to know a bit about how dew forms.
The short answer is that dew forms when the temperature of the air is too low to maintain water vapor in gaseous form. When that happens in the sky, you get clouds. When it happens near the ground, you get fog. And when it happens at the surface of a solid object, you get dew (or frost).
So why, then, can you get dew or frost when the air is perfectly clear?
The answer is that the space is cold. Really cold. Like 270C below freezing cold. If you expose an object to the night sky, heat from that object will radiate from warm to cold. This is called night sky radiant cooling. That process can easily bring the surface temperature of an object to well below the temperature of the ambient air. Once the surface of the object gets cooler than the dew point, dew or frost quickly forms. If you can shield the object from the sky, it helps to prevent this process. This is why dew is rare on cloudy nights (since the clouds act as an insulator). It's also why frost will form on a car windshield in the driveway, but not on a car in a carport, even though they are the same temperature.
So a nice, zero heat solution would be to block your scope's view of the sky. Of course, you can't observe when you can't see the sky. So a compromise solution is to extend the tube past the end of the scope. Depending on the where the scope is pointed, this can help quite a bit. For example, if you are looking at an object that is 45 degrees up, the dew shield will block the sky at the zenith, where most of the radiant heat goes. But since you can't completely cover the scope, dew can (and does) still form when conditions are right.
So what if you could keep the temperature of the front of the scope just a few degrees above the ambient air temperature? It turns out that this is a very effective way of preventing dew, but it does lead directly to your question.
To answer that, know that warming your optics causes a few problems. First, if you have heat rising from the lens, or corrector plate, or meniscus, or primary mirror (depending on what scope you have), it will disturb the air directly in front of the scope. This makes the image at the eyepiece less sharp than it should be. And second, heat actually changes the shape of the optic, introducing distortion. Also, if heat causes the optic to expand. Depending on how the optic is mounted in the scope, it could stress it, causing further aberrations (we call this one "pinched optics").
So a complete solution is generally composed of 3 parts:
- A dew shield as the first line of defense. A good rule of thumb for the length of the shield is about 1.5x the diameter of the scope. So if you have an 8" scope, you would want a dew shield that's at least 12" past the front of the scope.
- A dew heater as a second line of defense, to prevent heat loss that the dew shield doesn't block.
- A smart controller for the dew heater. The ideal situation is to have some mechanism that keeps the temperature of the front of the scope to just a tiny bit above the ambient temperature.
I have a couple of dew prevention systems that incorporate all three of these elements in different ways. The difference in my systems is the controller. I have an older dew controller that works with two temperature sensors. One of them is in contact with the front of the scope, near the lens. The other is held off the scope, so that it can measure the ambient air temperature. The controller works by comparing the two temperatures and adding just enough heat to keep the lens above ambient. The second system only uses single temperature sensor, for the ambient air temperature. But it also has a hygrometer to measure humidity in the air. It then does some math to calculate dew point and uses an algorithm to vary the current to the dew heater to keep it at an appropriate temperature.
Both systems have been 100% effective for me at preventing dew, no matter how humid the night. For purely visual use, the older controller is ideal. I have the newer one because it integrates with my imaging automation. But for each system, there have been plenty of mornings where the scope was literally dripping wet with dew, with the lens completely clear.
Oh, and there is one more reason to couple a dew shield with a heater. It takes just the slightest puff of breeze to move air across the front of the scope. If your only defense is a heater, blowing the heat away from the scope is not what you want. A dew shield helps to keep the air at the front of the scope still. This keeps the [small amount of] heat right where you need it.
I hope that this helps to clarify things.
