I took up the Sky & Telescope recent doubles challenge.
I tried to view omicron (ο) 2 Orionis.
aka SAO 94218, HIP 22957, BU (Burnham) 553, 9 Ori.
I don't want to make any spoilers here...
I'm curious what you see.
Posted 19 January 2023 - 10:02 PM
Posted 20 January 2023 - 12:32 AM
I'm curious about what you mean, have you had a look at it and noticed something odd? or do you not see what others are seeing? It's been a good while since I've had a look at doubles in that vicinity.
Posted 20 January 2023 - 09:08 AM
Well, it's a triple.
The 2 companions are not particularly challenging. WDS data updated circa 2013. Magnitude values look doable.
But I couldn't see them!
There's always the chance I was in the wrong field but checked a few times. I was certain I was in the right spot.
8" SCT, baader zoom eyepiece, SkyTools 4 Visual, fair to good seeing, average transparency, urban sky.
So I'm just curious people's assessment of this system. Was it easy or challenging?
Posted 20 January 2023 - 09:24 AM
What's your Bortle, Blake?
I must confess I have never observed Omicron Orionis.
Presumably you had no Moon in your sky.
Best regards from Aubrey.
Posted 20 January 2023 - 09:25 AM
Dunno, it's optical, both B and C seem to actually both of similar mag and not a mag apart, quite different proper motions so c has moved a bit relative to a, ac 111" in 69d in 2016, 41" in 53d for ab. b's probably mag 12.5 and c around mag 12.0, which is also not just a bit fainter than WDS but bc are reversed in brightness relative to WDS. So b may be a whole mage fainter than you are expecting whilst c is a bit fainter than thought it should be. Although it's a wide pair this is at least 8 mags worth of mag difference, and if you have image spikes or something because of the bright primary you could have just been unlucky as it's nearly a straight line triple.
Edited by yuzameh, 20 January 2023 - 09:27 AM.
Posted 20 January 2023 - 10:16 AM
I'm probably a Bortle 5 or 6. I have yet to do a NELM.
In the C8, I've reached mag 14--in dark sites of course!
I recently collimated (and it's nearly perfect).
That evening, last weekend, I was seeing mag 11 field stars, maybe a couple of mag 12.
That's what was confusing me. I thought I'd be able to tag the companions, despite the bright primary. I saw Rigel B no problem!
I guess I was on the wrong star...
I really wanted to hear from people who have seen omicron Ori lately to see if something had changed...
Posted 20 January 2023 - 05:37 PM
Nope, nothing's changed, the WDS values for 2013 and the gaia values for 2016 for sep and pa show little discernible change, it's just the mags are a bit off in WDS which is not a new thing as can be seen in many threads.
I know you'd be happier if someone observerd it but frankly they are not going to be any better than gaia at confirming things, the proper motion differences will have made a bit of difference in the six plus years since gaia but it will below what you can make out at an eyepiece just by eye.
Posted 20 January 2023 - 10:26 PM
Not seen it, since out of my "range".
Checking it in aladin (lite), it gives in G magnitude, pretty much the equivalent of the usual V mag:
B: 12.7m
C: 11.9m
So fainter as what WDS catalog says.
https://www.cloudyni.../#entry12412752
regards
Posted 24 January 2023 - 09:35 PM
Blake...
Had a chance this evening to image this target... See Below.
The larger image is from a stack of 5 2sec exposures. The primary star sort of gets "blown out", which may be part of your issue.
The smaller image, (upper right) is from a single 2sec exposure which shows the triple nicely.
Hope this helps.
Posted 24 January 2023 - 09:50 PM
Thank you so much, David, for the image.
I will dive deep into it to find those pesky companions.
Or maybe it will reveal I was on the wrong star!
Posted 24 January 2023 - 09:54 PM
Looking forward to hearing the results of your search...
Posted 25 January 2023 - 10:45 AM
Hi Blake!
I suspect the reason for you not being able to resolve the B & C components is that the magnitude data is suspect...at least according to the GAIA data. I have attached my typical narrow field images...one with and 1 without notation along with a not so well focused wide field image centered on 9 Ori as well as the DSS image and GAIA data from Aladin. I do believe a bit more optics will be required or some exceptional conditions...and you know how often we get that in this part of North America!!
Cheers, Chris.
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
