I have been imaging for almost 3 years now. My current main rig is a Quattro 200P on an EQ6, with a Canon 90D APS-C (soon to be modified) or an ASI533MC. I shoot at 800mm and 600mm with the use of a flattener @800mm and a Starizona Nexus @600mm. I also have a 135mm, 35mm and 16mm Canon lenses for wide field and Milky way shots. As you can see I have a pretty large gap between 135mm and 600mm I would like to fill - something in the 250mm-400mm range. So, I am looking at getting a good APO to fit the bill. I have a budget of $2500 to spend on the OTA + reducer/flattener, so higher end stuff like Tak, AP, and SV are probably out. What would you get in that focal range? Some that I have looked at are:
- Esprit 80
- WO Redcat 71
- Askar - several models in this range
- Orion EON
- Radian 75
- Astrotech - several models in this range. The new AT90CFT looks interesting, but its not out yet
- SW 190 Mak-Newt (not an APO)
Ideally, I would like to keep the f-ratio under f6 -- I'm used to shooting f4 or less. I also want to stay away from camera lenses as I have found them 1)difficult to hold focus, and 2) are limited for backfocus. I like OAG guiding, but 42mm backfocus usually means choosing between a filter or the OAG.
