C6, hyperstar, asi533mc-pro (power + USB cable), and Starizonas supplied camera spacer / adapter (no filter drawer).
The way I see it I have two 'easy' options... either run both cables together, and exit them out the base of the dew shield, close to the collector, through the provision the shield incorporates for this purpose (as well as, of course, the dew heater ring wiring), or... run them out the front of the dew shield, where creating a 90-degree angle with the wires to (hopefully) achieve attractive diffusion spikes would be possible. Neither option strikes me as ideal, particularly since it's as important to me to use the dew shield for capturing darks and flats as it is to achieve eye-pleasing diffraction patterns. I also don't know what, if any, difference there is between these wires crossing in front of the optics directly in front of the collector, vs approx 10" in front of it as would be the case if I came out the front of the shield.
I'm ok with modifying the shield as needed to achieve my desired goals, if necessary. But I'd rather not replace it as its already purchased and in every other way I'm really pleased with the construction and fitment.
Any help, advice, or suggestions would be greatly appreciated. I have this question in to Starizona and will post their response here when received, but I'm curious what y'all have done and am hoping for 'first light' tonight!
Edited by AnotherMoneyPit, 25 January 2023 - 03:04 PM.
