I don't have a laser pointer that can fit the focuser.
If there was a misalignment, what would be the "symptoms'?
At f/9, it is unlikely that there would be any symptom at all. At this kind of focal length and focal ratio, a bit of focuser misalignment is meaningless unless you are imaging. If you are imaging, focus wont be the same in all four corners of the chip.
Visually, the only test you can do is kind of insensitive but if you don't have a laser, then it is all you have. To do this test, you need a very bright star like Sirius and a wide field eyepiece.
Bring the star exactly to the center of the field and defocus about 10mm.
Starting from the very center of the field, move the star all the way in any direction. As you get to the edge of the field, you should see the front end of the focuser baffle cutting into the light cone. You will know it when you see it. Here is the subjective part. You have to estimate how many millimeters from the edge of the field stop that happened.
Next, move the defocused star to the opposite side and do the same observation. If the focuser is tilted one of those directions, you will see that the cone starts to cut off a bit sooner or later than the other side.
Repeat this at 90 degrees and 270 degrees from where you started.
The thing is that you need more than just a small amount of tilt to actually be able to see this happen unevenly unless you have a very precise way to measure where the cutoff occurs and in an f/9 scope, the fully illuminated field is going to be really large, maybe like 30mm or so, so your field stop has to be at least this big and probably a big bigger, but the closer the field stop is to the fully illuminated circle, the more senstive the test will be. If the circle is 30mm and you use a field stop that is 31mm, the cut should start 1mm inside the field stop in all directions.
Does that make sense?
You can buy a laser for $25. Much easier and more accurate.
Here is the bad news though.. In most new scopes, if the focuser is titled, you really can't do anything about it.
The good news though is that because of the way they are made, it is highly unlikely that you have bumped it out of alignment and at f/9, it would take some pretty serious tilt to cause a problem.
Edited by Eddgie, 25 January 2023 - 06:07 PM.
