I'm not sure whether this should be in the beginner or advanced forum. Since it's a flats problem, I'm going to put it here in the beginner area.....
I am working through a new telescope; a Tak E130D. I had it out for my first images last night. I took flats and some images of the Witch Head nebula. Going through the data today shows the calibrated results look like the flats are over correcting.
I have bias calibrated the individual flats (no dark calibration on the flats). Then integrated the flats.
Here's some stats on my data:
Bias median value: 3.065^10-3
Dark median value: 3.07^10-3
Lights median value: 8.15^10-2
Flat median value: 4.25^10-1
The Bias and Darks are very close in median value, but the calibration images are correctly ordered in terms of median (and mean) values.
I generally calibrate with Bias and Flat during the image calibration step, then calibrate with darks during cosmetic correction.
So, far I've been scratching my head. I can't figure out why my process that works so well for my FLT132 does not work at all on this data from the E130D.
I took a look at the histogram of the flat from my FLT132 and compared it to the histogram of the flat from my E130D (both from my ASI6200MM). The histograms look VERY different. I should also mention that I take my flats at gain 100 and offset 20.
Flat histogram from the FLT132 flat:
Histogram from the E130 Flat:
Also, the unstretched images of these two flats look very different. While both the flat from the FLT132 and the E130D have the same mean and median values, the flat from the FLT132 looks like a flat, gray image. The unstretched flat from the E130D looks like a stretched image; you can clearly see the vignette even though the image is still linear.
Obviously, the E130D is a LOT faster than the FLT132 (f/3.3 vs f/7). For my individual flats on the FLT132 the exposure time is 0.99 seconds. For my individual flats in the E132D the exposure time is 0.41 seconds.
So, what's going on here? I can not get my lights correctly calibrated and remove the vignetting. The statistics from the E130D flat looks good, but the histogram is very strange. Thoughts?
Edited by dcm_guitar, 25 January 2023 - 05:52 PM.
