Newbie Pixinsight masking question
#1
Posted 04 February 2023 - 05:49 PM
So, I used the dynamic paintbrush tool to mask them from the original image. But I cannot figure out how to copy them over to the stars image. It's probably incredibly simple, but I'm just not seeing it.
Thanks in advance!!
#2
Posted 05 February 2023 - 10:13 AM
I generally use PixelMath to combine images.
The correct way to do it depends heavily on the nature of the two images.
The simplest way is to just add them together. This works if the comet image is completely black except for the comet, and the stars image is completely black except for the stars. That expression would look like:
comet_image + stars_image
If there is significant background in both images, then you could combine them, keeping just the brightest pixels:
max(comet_image, stars_image)
Most of the time, when I separate the stars, I use StarXTerminator and descreen them. The proper way to combine them back in is then to use the screen blend mode in PixelMath:
combine(comet_image, stars_image, op_screen())
There are countless other ways to do this, but it all depends on the specific relationship of the images that you are trying to combine.
- Yoddha, DirtyRod and DanMiller like this
#3
Posted 06 February 2023 - 01:00 PM
Hello, I am doing my first comet stack and in creating the star image, several small galaxies were left behind which I would love to be in the final image.
Thanks in advance!!
If you generated a "stars_image" and a "comet_image" from your "original_image" using Starnet++ or StarXTerminator then the "comet_image" will contain background galxies. The simplest way to get them in your "stars_image" is to CloneStamp the galaxies OUT of your "comet_image" and then subtract the "new comet_image" from your "original_image" using pixel math. This will generate a "new stars_image" that contains stars and background galaxies:
stars_image_new = original_image - comet_image_new
Regards
Derek
- DanMiller likes this
#4
Posted 06 February 2023 - 08:24 PM
I really liked the method used in this video: https://www.youtube....h?v=SCMyGNZlx5o
- drake likes this
