I've just started with astrophotography, and after a few attempts I've decided that it's a hobby that will keep me interested me for some time; so I decided that I will spend some money on some upgrades, and I'd like to have some suggestion on where to spend to get the best results for the money.
Right now I use a Canon EOS 500D/Rebel T1i with a camera tripod and a kit 18-55 f3.5-5.6 lens.
Ideally upgrade(s) will allow me to:
1) more immediately improve on my photos
2) do some astrophotography while on holidays; since I do my holidays on a bicycle, the upgrades must be compact, lightweight and sturdy enough to survive some rough handling.
The absolute maximum budget must stay under 200€, but I would rather keep it around 100€-150€.
I don't mind buying used.
The item (2) is only relevant on my summer vacation, so it's not an immediate goal; at the very least, I think I could go for my actual equipment but with a prime lens plus a "barn hinge" tracker.
To improve on my photos instead I feel that I need a (motorized) tracking mount, plus a prime lens or a telescope.
So, for the mount I was looking on ebay, and I found some cheap Celestron EQ1 mounts, that can be motorized with little effort (or little money): are they any good, or it's better to stay away from them?
For the lens, I was thinking of buying a 135mm or 200mm prime lens, that I could also take with me on holidays.
If instead you thing I should go for a telescope, which is the minimum you recommend? What should I look for?
I've also seen some reflecting telscopes for around 190€ with the mount, are they good or is just a waste of money?
Thanks for the advice
Andrea
