I used steel pipe strapping bolted to the frame like this:
Edited by John Fitzgerald, 06 February 2023 - 08:05 AM.
Posted 06 February 2023 - 12:09 AM
Since you already have holes for the feet, a simple ratchet strap in the center would anchor the tripod quite effectively.
Posted 06 February 2023 - 08:07 AM
The way my buggy and tripod is configured, ratchet strap is not feasible.
Posted 06 February 2023 - 12:33 PM
That looks very secure John.
Posted 06 February 2023 - 06:16 PM
Those straps are good for lots of little things.,very strong.,
Posted 06 February 2023 - 11:29 PM
Ok here is mine , i built for a member ,
the tips sit in pockets, preventing any movement.
pulls equally on all three feet/ legs equally , this keeps the tripod absolutely secure to the buggy .
One strap, if you need to tear down for transport , QUICK, setup...Ditto.
No marring of the legs , no slipping . And more secure
the buggy for my C14 being the largest .
Posted 07 February 2023 - 12:04 AM
I have a big 3/4" Baltic Birch plywood spreader / shelf right above the bottom leg extension mechanism on my Atlas tripod.. No way to put a tie there. The spreader is only about 12 inches off the ground (if the tripod was sitting on the ground).
Posted 07 February 2023 - 08:09 AM
Heres an atlas on a buggy i built that is adapted to hold many different tripods , different sizes , and pitch .
The strap, i have used attached to the mount , and tried at spreaded .. i prefer the mount . A wrap around loop crossed on itself and hooked to the base .
I did not use the spreader , as the tripod sits in SOCKETS in buggy , unable to move oor shift . The spreaded not needed . One less piece to haul around .
Posted 07 February 2023 - 11:37 AM
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
