I've spent a better portion of the past week reading advice here on CN and perusing book edited by Christophe Pellier, but the ever-shifting market for filters is leaving me somewhat confused.
I have C8 and 678MC and 1600MM. I will have (sporadically, at best) access to friend's C11.
The main planets are out, so I thought about turning to Venus and Uranus for the foreseeable period, they will be well visible from my balcony.
Visible light situation is clear, 678 and ADC, with limited contrast, if any.
With imaging in IR and UV I have some dilemmas, have never done it before.
For Uranus I have to get a IR pass, probably Astronomik 642. I can use both color or mono for this task, which one should be preferred? I ask also because, if I am not mistaken, critical sampling in deep red and IR is not 5x, but rather around 3.5x, so 678 would oversample and 1600 would slightly undersample. Does it matter? Is there any particular advice on focusing in IR in mono or color?
As for Venus and UV, looks like quite a few on here recommend NOT using a dedicated 'brutal cut' UV filter for SCT due to correction issues, but rather a #47/Ir-Cut combo? Is that a way to go in absence of Astrodon Johnson U filters. The new transmission curve for Baader Johnson U looks quite different. Any alternatives are reccomended. Can Astronomik L2 be used with #47 (transmission curve looks like it does not really cut at 400), or should one aim at a dedicated IR-cut? I cannot find any transmission curves for #47s that are sold. IDAS 410 has one, but for a price - is it really worth it?
I have two more dilemmas re Venus.
First, I see that one should use ADC with mono camera. Why so? I understand for OSC or RGB, but here would be imaging only in UV or UV/blue. Is that because dispersion is at the strongest in short wavelengths? What is more - just how do I do ADC correction in UV...when there are no colors to correct? I am at a bit of a loss there.
Second, critical sampling at 390nm at 3.76 pixel size is around f/23. So I would absolutely have to use barlow in order not to massively undersample in native. Or would leaving out UV-absorbent barlow better than getting close to critical sampling? Venus is small as it is... Are all barlows equal offenders when it comes to UV absorption? I have VIP and PM 2.5...
