New Binocular Case
5 replies to this topic
#1 Craig Simmons
Craig Simmons
Posted 06 June 2004 - 12:57 PM
My case that came with the Obie 20x90s broke in two places (latch and side strap attachment) this past week. The binos stayed in collimation after the fall. I had heavily foamed lined the Obie box. I went over to the local Conatainer Store and bought a plastic case (double walled) with latches for about $30. I added some foam I had lying around. Works great. I've used these cases before with my Stellarvue AT1010 and they hold up well.
#2 KennyJ
KennyJ
    The British Flash
Posted 06 June 2004 - 02:39 PM
Nice case Craig.
Well worth around around $30, I would say.
I hope your experience serves as a warning to others.
Consider yourself fortunate the collimation ( or something even more serious ) was not damaged.
I think you've suffered you fair share of "bino damage" already for one year !
Regards , Kenny.
#3 wilash
wilash
    Fairy Godmother
Posted 06 June 2004 - 06:58 PM
Craig, I did a similar thing for some view camera lenses once. I used a sheet of an insulating foam from the local hardware store. It was easy to cut and I was able to make a faily good "mold" for the lenses. It can take a lot of space out of the case to prevent the equipment from rattling around.
#4 Guest_**DONOTDELETE**_*
Posted 07 June 2004 - 07:20 AM
A "container store"? That's one dedicated store! The styrofoam holder sent with my Oberwerk binos is so-so, but it obviously can be easily punctured. I like your rigid bino box. I hope it passes any unfortuante future tests!
#5 Craig Simmons
Craig Simmons
Posted 07 June 2004 - 10:47 AM
The strap on the side of the Obie box tore right thru the leather(?) riveted attachment. I had installed (3) 1 1/2" pieces of foam on the bottom, (1) 1 1/2" pieces on each side and two 1 1/2" pieces on top just before going on vacation last week. The binos fell from about waist height (slung over my choulder) and landed on a corner of the box. I highly recommend getting a replacement container for those that are still using the stock Obie box.
#6 Guest_**DONOTDELETE**_*
Posted 07 June 2004 - 11:19 AM
I agree. Thanks for the advice.
