So now that we may be done throwing food at each other. let's look at some serious attempts to find the true (or realistic or natural) color of the Trapezium. This shows what can be done and how objective it can be, especially when most of the light comes from various narrow-band sources whose wavelengths (and human responses to those wavelengths) are known. Stars or other approximately black body radiators can also be accurately assigned their true color. Spectrometer data can be used to check or even artificially generate images of such objects.
https://clarkvision....ium.true.color/
https://www.dpreview.../thread/3969219
And since BQ mentioned Lodigruss, here is his take on the same subject:
http://www.astropix....color-m42-core/
The captured images and the image synthesized from spectrometer data agree reasonably well, for many tested digital cameras.
This is one way to test our equipment to see if it produces true-color (realistic color) astro imagery.
And it turns out that there are "sufficiently large telescopes" to allow our eyes to begin to see the colors of the brightest nebulae:
https://www.cloudyni...ographed/page-2
though there is a fair bit of individual variation.
And now we've come full circle—which is another square on the CN Controversial Topic Bingo card. We're still missing a few, mostly what I would consider negative
- TOMDEY Facts (these are always super-fun and informative!)
- Deep pontifications of disproven dogma with certitude by demi-experts (these are painful and counter-productive)
- Thread hijacked (these can be fun, particularly when friends plan or discuss day-to-day activities)
- Ad hominem attacks between experts (these are the most painful to watch—I witnessed Lodriguss's meltdown in near-realtime)
- Moderator warning
- Thread locked
But this is a choose-your-own-adventure bingo, mate! You only have 63 posts, so I'll assume you don't know it works. As the OP posing the controversial question, you have to lay down the ground rules for exchanges. For instance, going off your two posts above:
1. Arguments only with information and charts from Roger Clark's site (or just links to entire threads that summarize our position):
Random quote #1:
"Color Space describes the different colors, called a gamut, that a device like a computer monitor or print can show, as well as the range of colors that an imaging device, like a digital camera can record. Color space models are simplified standards for devices and not a precise description of human color perception. The color displayed by different devices can appear different even when calibrated to the same color space. The black level also impacts the gamut and color saturation of images." [Source, emphasis mine]
Random Chart #1:
[Source]
Random Links:
#1: https://clarkvision.....the.night.sky/
#2: https://clarkvision....s/color-spaces/
#3: https://clarkvision....or-and-critics/
2. Arguments only with links to CN
2a. Only threads with TOMDEY posts
2b. Only threads with Lodriguss posts
2c. Only threads with Mark posts (that square already got played early in this thread)
(We could probably make an entire bingo card out of these…for each forum, at that!)
I much prefer the Road Less Traveled square: actually measuring and comparing what we're trying to prove or disprove. After all, this is an imaging forum! So that is the adventure path I would choose. That would look like this:
You've picked Trapezium, among the largest and brightest nebula in the sky (waaay above the noise and light pollution and so easy to obtain data). Your calibrated unmodded camera is your spectrometer. Did you calibrate your sensor (per Clark)? Have you taken a picture of Trapezium? At what RA/DEC point or points are you measuring chromaticity (xy, see Clark)? At what pixel scale? What are your measurements? Which of the reference "true color images" are you comparing to? Did you correctly convert the reference image color data from sRGB to xy? And what stretch do you plan to use for your stretched image? This last one is critical because the only way to view linear data "truly" is to do a gamma stretch with the gamma of your calibrated BT.709 monitor (the sRGB stretch is more contrasty so it looks better, but is not "true").
So what path do you choose?
BQ
P.S. You don't have to prove you can see DSO color at the eyepiece to me. I have literally seen DSO Ha at the eyepiece:
https://www.cloudyni...h-mak-cass-180/
And I have many friends who see the core of the Milky Way at zenith as green.
Edited by BQ Octantis, 05 March 2023 - 08:52 AM.
