I'd like to share with everyone a project I've been working on for a bit now, I call it the PiFinder. It's a plate solving telescope finder based around a Raspberry PI, RPI HQ Camera, and custom UI 'hat' that allows no-setup telescope positioning, catalog filtering/searching, and push-to guidance without any additional equipment. The unit fits on standard synta finder brackets and should work on any Alt/Az scope.
It's a bit tough to describe, so here's a photo on my scope:
Here's a better view of the hardware and some of the screens related to catalog/target selection, push-to and charting
And an image from the user guide of the keypad/screen and UI
* Fully open source design and software so you can build your own and contribute ideas and improvements
* No encoders / star alignment or other setup
* Quick (< 1.5s) exposure/plate solving to determine telescope pointing position
* Integrated Inertial Measurement Unit to update position while moving scope/between solves
* GPS integration
* Catalog search, filtering and object information display
* Push-to guidance via directional arrows, or real-time chart with target plotting
* Full chart plotting with optional constellation lines, reticle and DSO's. Multiple zoom levels and the chart tracks with the scope as it's moved.
* Includes logging capabilities to record observations with sky conditions and some notes
* OLED screen with easily adjustable full-range brightness. Bright enough for indoor/daytime use and gets dim enough for demanding dark sky sites.
* Can be built with rechargeable battery, or run from scope provided 5v power
I've used this for a few observing sessions now and it's really let me spend much more time at the eyepiece as it combines target selection, charting, pointing/finding and logging right at the eyepiece. I hope some other folks find it interesting and potentially build their own! A full user manual and build guide, along with everything else needed to build one, is available at:
https://github.com/brickbots/PiFinder
I want to thank Dale Eason for posting about his Telescope position system without encoders as it really made me believe it was possible and prompted me to dive into this project. Thank you!
Edited by brickbots, 01 March 2023 - 09:26 PM.
