Here is v1.1 of Plate Align to add alignment points to CPWI from platesolving instead of centering stars:
Connect CPWI to your mount however you ordinarily do so. Everything is the same up until you need to center stars. Make sure you know how to use CPWI properly. Use CPWI with an eyepiece a few times if you need to make sure.
Open Plate ALign, and connect CPWI and a camera. Check to make sure your latitude, longitude, and system time are correct or the mount will move to incorrect places.
Find focus, exposure, and gain settings that permit a plate solve. It is better to use your telescope rather than a guide scope. Try the settings far from the Milky Way to make sure it can solve everywhere.
Double click on the chart to add an alignment point at that alt/az location. Add as many as you wish, but remember that it goes in order. Try to minimize the slewing distance between points. When ready, run the alignment.
Revisions Plate Aign v1.1:
Added Focuser Support
Added Focal Length update after first Solution for faster solving
Added units to slew speed
Added checking ASTAP's default location
Fixed window focus changing when validating text boxes
Fixed to prohibit SIMBAD lookup and goto during alignment
Fixed to check whether Epoch is one of J2000.0 or JNow in Settings file
Fixed to slew to Az Alt based on selected Epoch
Fixed to only write settings for connected components
Fixed to write FITS Data asynchronously in blocks of 28800 bytes
Fixed to use Haversine formula with small angles
Changed constructors for ASCOM classes to permit reading properties before connecting
Changed icons of child windows
Changed ASCOM panel layouts
Changed time precision to include milliseconds
