SOMEHOW THIS POST FROM ABOVE WAS REPOSTED….
Hi Greg
Thank you for providing the link to the Bruce Gary filter discussion. It was Bruce’s final paragraph (quoted below) that initially convinced me to acquire and use the CBB filter.
His analysis presents the case for that filter as well suited for amateur astronomers doing work on confirmed exoplanets . More recently, a resource for determining the ‘limb darkening’ coefficients for use with the CBB filter has been published and is available as an online resource.
All this is great but, for the OP, who is interested at this point in just testing out the process of observing and detecting an exoplanet transit, I’d still maintain that using ‘no filter’ would be perfectly reasonable. This approach defers the cost of a filter until the OP decides whether to pursue this line of work and, more importantly, it results in a higher SNR which will likely help with his initial attempt at transit detection.
If he decides to pursue exoplanet work, he’ll likely want to acquire the standard photometric ‘V’ filter to start off as recommended to me by the AAVSO.
regards
Gary
“To my knowledge this is the first report of results from an observing session designed specifically to identify optimum filter choices for exoplanet light curve observing. There may be flaws in my procedure, and I am open to comments on an improved observing protocol or an improved image analysis protocol. I welcome others to conduct their own “filter playoff” observations, and share them with the community of amateur exoplanet observers. Until others confirm what I have found it is fair to characterize my results as merely “suggestive.” The suggestion, to be explicit, is that the overall best filter choice is CBB-band.”
Edited by GaryShaw, 13 March 2023 - 09:07 AM.
