Frank, Thanks for confirming about the halo situation for the Chroma filters. I may ask you again in half year or so to see if the conclusion still holds after you use it a few more times. In my case, I have several different filters in my wheel. Only when I switch to the classic Johnson filters there are halos. Since the only thing that changes is the filter, and since the filters that have halos are the classic Johnson filters, I believe it is reasonable to conclude that the halos are caused by the filters but nothing else. This makes me consider the Chroma ones.
Jon, I believe DSS is Digitized Sky Survey, which is the scanned data of the photographic plates from the Palomar Schmidt and UK Schmidt. I don't think their B and R are Johnson B and R. They must be taken with different Kodak 103a emulsions, one with better red sensitivity and the other with better blue sensitivity. One of them ® might be used together with a filter to cut off the blue, but I am less certain about this.
Regarding the bell-shaped classic Johnson-Cousins, and square ones with sharp cutoff, I highly believe people should move to the latter if the goal is scientific studies. The original Johnson-Cousin set was developed for phototube photometers, which typically had only one phototube in it (one pixel) with large "pixel scale" (like several arcsec per tube). They can achieve highly accurate photometry, and therefore the exact shape of the filter matters. Also, at that time, the evolution of phototube was quite slow. A certain type of product could easily get widely used in observatories for years before a new generation of products appeared. What this means is that astronomers in different places could use photometers of identical QE curves for their works. And if the filters are also identical, they can easily compare their results to very high accuracy (way lower than 0.01 magnitude).
Now that kind of accuracy is gone. CCDs have different QE curves from the old photometers. And there are many different types of CCD in the market, and they evolve fast. Basically the QE curve of the camera in every observatory is different. So it is already not very meaningful to require using a Johnson-Cousins filter set that's identical to the ones people used half a century ago. Furthermore, CCD has many pixels, and that leads to a series of calibration issues. Today's good CCD calibration is like a joke if we use the standard half century ago for single-pixel photometers. We just can't get the accuracy of phototubes that used to provide us. But CCD has many pixels. This advantage trumps the sub-0.01 mag accuracy.
Because accurate photometry (at the level half century ago) is no longer possible, and because a fixed QE curve is also not possible, some astronomers have already let go the idea of using filters that are identical the the old Johnson filters. It just means nothing. Today, many observatories shift to the Sloan filters and abandon the Johnson-Cousins system. Among those who still prefer the Johnson-Cousins system, some of them shift to square-shaped transmission curves with sharp cutoff, like the Chroma ones. They still call such filters Johnson-Cousins ones as long as the effective wavelengths match. This mimics the photometry done in the "real" Johnson-Cousins system to perhaps 0.05 mag level (hard to do better with CCD anyway). My favorite example is Subaru's SuprimeCam filters. There are other examples.
Once we let go the sub-0.01 mag accuracy, the advantages of square-shaped interferometric filters for scientific studies are vastly clear: better overall QE, better defined passbands, and no halos.
As for Chroma, I have no idea why they call their Johnson-Cousins filters "Bessel." Even Bessel himself doesn't call them Bessel filters. See his article here.
