Some of you may have read my prior thread discussing my newfound adventure into the world of DPAC testing. It’s been quite educational, and has markedly increased my understanding of just what makes these refractors of ours “tick.” I’ve learned not only what makes our fine refractors so good, but what makes others less than desirable. And no, I’m not going to revise my sig line “I’ve never met a refractor I didn’t like.” Here I present the example of a refractor that has one of those “less than desirable” lenses. Yet, I still like this refractor, as it’s probably taught me more about optics than all of my near perfect apochromats put together.
Here in my prior DPAC thread I presented the test results of this particular Orion 120mm f/8.3 doublet achromat: https://www.cloudyni...nge/?p=12558236. In summary, the optics appear to have significant overcorrection (perhaps 1/2 wave, although I haven’t measured it), and two large zones centrally and peripherally.
So I got to wondering whether maybe a prior owner had disassembled the optics and perhaps reassembled them incorrectly. The scope was easy enough to disassemble. The fixed dew shield was simply a press-fit one, and easily slid off. Next there were three Phillips head screws attaching the lens cell to the tube, and those were easily unscrewed. The lens retaining ring in front of the optics had two small slots for a spanner wrench. While I don’t own a spanner wrench that large, using the tip of a fine-point Phillips head screwdriver I was easily able to unthread that. It was attached loosely enough that the tip of a paper clip would have easily worked as well. Underneath the retaining ring was a rubber grommet, which easily fell right out. I then carefully removed the lenses from the lens cell.
