Let me try to summarize this discussion for those using a telescope for eclipse PHOTOGRAPHY and working at an effective focal length of 500mm to 1000mm. Versus talking about VISUAL observing through magnifying gear. Note: the use of capitalization below is just to be clear about the important distinctions, please do not consider the capitalization as being arrogant about the discussion. It is meant for clarity.
For PHOTOGRAPHY it is safe for your equipment to remove your FRONT aperture solar filter 30 seconds before C2 to start imaging. If you did not do it this early, you could not image the diamond ring. After C3, for PHOTOGRAPHY, it is safe for your equipment to continue imaging for 30 seconds before you replace your solar filter. If you did not continue to image for this long, you could not image the diamond ring again.
For VISUAL OBSERVING through ANY magnifying equipment, it is ONLY safe to look through the gear WITHOUT the FRONT aperture solar filter at the Corona during Full Totality. Between the times of C2 and C3.
For any commercially available solar filter that blocks greater than 99% of the visible light, glass or film products, they are always placed in FRONT of the gear aperture, preventing the light from entering the optics.
Hope that helps, thanks. Gordon
Edited by foxwoodastronomy, 04 May 2023 - 06:42 PM.
