A big prominence liftoff timelapse, 6th March 2023
Solar
29 replies to this topic
#1 acasely
acasely
Posted 17 March 2023 - 12:57 AM
I had seen that a filament was beginning to detach from the Sun on 6th March, and decided to get in to the 38C heat and do some imaging. I took a sequence of 40 frames over 35 minutes in great seeing for my favourite solar timelapse so far. The prominence reaches about 250,000km high (Earth is about the size of the little hovering blob under the prominence's arch). Lots of plasma rain, movement in many directions, and solar wind buffeting around the ragged edge of the filament as the left edge detaches. Much of the remaining material drains down magnetic field lines to the right, and it had mostly dissipated within an hour or so. So much motion on a big scale, definitely my favourite animation I've made so far.
Skywatcher Evostar 100, Quark CS, ZWO ASI174MM, 40 x 20s, ~2600 frames per capture.
  • EricCCD, Yu Gu, Tapio and 37 others like this
#2 Astrojensen
Astrojensen
  • Loc: Bornholm, Denmark
Posted 17 March 2023 - 02:23 AM
Clear skies!
Thomas, Denmark
  • Spikey131, acasely, ziggeman and 1 other like this
#3 R Botero
R Botero
  • Loc: Kent, England
Posted 17 March 2023 - 03:25 AM
Wow, wow,wow! :bow:
  • Spikey131, acasely and ziggeman like this
#4 Spikey131
Spikey131
Posted 17 March 2023 - 05:55 AM
Really, really nice work!
  • acasely likes this
#5 rigel123
rigel123
  • Loc: SW Ohio
Posted 17 March 2023 - 06:15 AM
Excellent animation!
#6 Averton
Averton
  • Loc: Melbourne, Australia
Posted 17 March 2023 - 06:16 AM
Brilliant time lapse Andy - really well done!!!
You have to enjoy seeing as good as that and you made good use of it.
#7 MalVeauX
MalVeauX
  • Loc: Florida
Posted 17 March 2023 - 06:23 AM
Truly awesome!
Very best,
#8 philmor56
philmor56
  • Loc: Bolton, ON
Posted 17 March 2023 - 06:30 AM
That's a keeper for sure there Andy!
Cheers
#9 gstrumol
gstrumol
  • Loc: north of Detroit, Michigan USA
Posted 17 March 2023 - 07:01 AM
Worthy of a "4 bow.gif " rating!
#10 joshua_vise
joshua_vise
  • Loc: South Korea
Posted 17 March 2023 - 07:22 AM
Amazing job!
How fast do you suppose the material is moving as it drains down the magnetic lines back into the sun?
#11 torsinadoc
torsinadoc
  • Loc: Fayetteville AR
Posted 17 March 2023 - 07:30 AM
Excellent animation and image
#12 gstrumol
gstrumol
Posted 17 March 2023 - 08:08 AM
It seems like you used the Chromosphere version of the Quark, and still got amazing prominence images. So why do they sell a prominence version? Every Quark I've seen here has been with CS version. confused1.gif
#13 rachnoman
rachnoman
Posted 17 March 2023 - 08:40 AM
Great capture and processing. Thanks for sharing your good work!.
#14 Classic8
Classic8
  • Loc: Naperville, IL, USA
Posted 17 March 2023 - 09:01 AM
#15 snommisbor
snommisbor
  • Loc: Cedar Park, TX
Posted 17 March 2023 - 09:14 AM
#16 MarlinS
MarlinS
Posted 17 March 2023 - 03:24 PM
Incredible!!! Best Prom Animation I’ve seen!!! Strong work!!! A high bar for us novices!!! Can’t wait to get into animation. Thanks for sharing.
#17 sk9.florida
sk9.florida
Posted 17 March 2023 - 06:00 PM
what a feast to the eyes!! amazingly captures. thank you for sharing, simply superb!!
#18 Classic8
Classic8
Posted 17 March 2023 - 07:13 PM
Amazing job!
Interesting question, I'd like to know that too. If we knew how big the prominence was, maybe based on what percent of the sun's surface is visible in the image, then use the total time elapsed, you would know approximately how fast it was going.
#19 yuzameh
yuzameh
Posted 17 March 2023 - 10:41 PM
Well, that's an apod!  Animated picture of the day!
#20 acasely
acasely
Posted 18 March 2023 - 09:59 PM
Aw thank you very much for all the kind comments! Will reply to a couple of questions shortly
#21 wxcloud
wxcloud
  • Loc: Under bortle 8 Colorado skies
Posted 19 March 2023 - 01:32 AM
shocked.gif bow.gif WOW!
#22 BYoesle
BYoesle
  • Loc: Washington USA
Posted 19 March 2023 - 12:50 PM
#23 davidpitre
davidpitre
  • Loc: Central Texas
Posted 19 March 2023 - 08:17 PM
Excuse my ignorance. But each of your frames was just a single frame, not a stacked frame, correct?
#24 acasely
acasely
Posted 19 March 2023 - 08:55 PM
I can't comment directly, but one of the top imagers on this forum (MalVeauX) has commented on it elsewhere, and a I suspect he is right - the logic is sound that the better the etalon (narrower bandpass) the better contrast the prominences will be so long as it's well tuned, and the Quark CS version has a narrower bandpass than the Quark Prom. The images will be dimmer visually, but with a reasonable imaging camera, that doesn't matter. For reference, I image prominences at ~220-240 gain and 2.5-3ms exposure with my Quark CS, and on the live view the prominences are not visually spectacular, often nearly invisible. I use the "screen adjustment" tools in Firecapture to help with framing the prom during capture. The hardest work is getting or constructing a decent flat field for the frame, to smooth the asymmetric glare from the bright main disc of the Sun.
A single raw frame (each video sequence for each processed frame in the GIF has ~2600 raw frames):
And stretched in PS to show what's visible in a single frame:
Edited by acasely, 19 March 2023 - 08:59 PM.
  • R Botero likes this
#25 acasely
acasely
Posted 19 March 2023 - 09:14 PM
Amazing job!
Good questions! I've done some back-of-the envelope calculations on my image. It assumes that the image scale is ~223km per pixel, so Earth would be ~57 pixels wide if it were imaged from this distance, and my full-disk sun mosaics come out around 6145 pixels diameter or so. It also assumed that all the motion is perpendicular to our line of sight, so these speeds are minimum values, some speeds could be quite a bit higher.
A droplet on the left side of the arch falling back towards the Sun: 99pixels (22058km) in 3.4min = 108km/s
A bright blob rising quickly as the left side disconnects: 63px in 4.2min = 56km/s
Some material rising in the diffuse cloud at upper left: 112px in 5.9min = 71km/s
a faint streamer cutting across the arch towards the Sun about mid-sequence: 88px in 2.6min = 126km/s
Two different blobs in the tight streamer flowing down to the Sun along the magnetic field lines:
150px in 4.2min = 133km/s
113px in 3.6min = 117km/s
Some plasma rain near the foot of the tight bright stream: 107px in 3.4min = 117km/s
For comparison the ISS travels at 7.7km/s, and a passenger plane at 0.25km/s!
  • R Botero and joshua_vise like this
Also tagged with one or more of these keywords: Solar
