LX90 8" autostar mount 180 degrees off goto Azimuth
3 replies to this topic
#1 Melachrino2020
Melachrino2020
Posted 17 March 2023 - 09:44 PM
After many weeks of cold, bad weather, starting and initializing the Meade Autostar in my LX90 8" system, the Azimuth GOTO is off by 180 degrees.
Scope has not moved location, and no update or modification has been done to the system since it was performing adequately before now.
Checked initialization entries, calibrated motors. Did not help.
Any suggestion before attempting a reset ?
Thanks.
#2 kgb
kgb
  • Loc: Long Island, NY
Posted 17 March 2023 - 09:55 PM
You checked your latitude longitude ?
#3 michael8554
michael8554
  • Loc: Wiltshire UK
Posted 18 March 2023 - 04:14 AM
Please post your setting up routine:
Control panel facing south
OTA pointing north.
Enter time and date
What kind of Star Alignment ?
Unless you're in the southern hemisphere ?
#4 Melachrino2020
Melachrino2020
Posted 18 March 2023 - 08:42 PM
Rechecking the well known and standard initialization process for my Meade 497  Autostar, there were no entries that were incorrect.
Therefore, it would appear that even though the initialization readout was correct, then it most likely meant that a crucial memory location had somehow been corrupted.
I had run into this type of situation in my former life, so I resorted to the recommended RESET option, which would hopefully clear first the erroneous memory location and allow a correct entry to be saved instead.
Which is what happened. The LX90 now points in the correct direction. Hope this helps others.
Thanks for the suggestions.
  • Skywatchr likes this
