Hi guys.
There seems to be a weird green tint to my Rosette Nebula .
Is it possibly due to my IDAS NBZ Nebula Booster UHS Filter ?
Reif
Posted 19 March 2023 - 02:01 AM
I've seen more pics with green in the Rosette. Including my own pics. The colors are real.
Posted 19 March 2023 - 04:31 AM
Exactly how my STF's come out. Rather pretty.
Dan
Posted 19 March 2023 - 02:06 PM
Dan
Thanks.
Another strange thing is in SharpCap, NINA, and ASIStudio Deep Sky Imaging, when I stretch the image the entire background turns green. Does that also make sense with the Filter?
I'm confused
Thank you ,
Reif
Posted 19 March 2023 - 02:12 PM
Thank you Robert!
What do you use to remove the green tint? Or is it the real color?
Thanks again ,
Reif
Edited by reifheck, 19 March 2023 - 02:13 PM.
Posted 19 March 2023 - 02:17 PM
Thank you Robert!
Thanks again
Reif
Where to begin… there are many ways, what editing software are you using?
Posted 19 March 2023 - 02:22 PM
I have Photoshop, Photoshop Elements, and Photoshop Lightroom.
What do you recommend and use?
Reif
Posted 19 March 2023 - 02:27 PM
Another thought Reif and Robert,
On the 533mc pro the Bayer Matrix pattern is RGGB. One additional green pixel. In a linked stretched image there is a major green cast over the whole image. I remove it temporarily with an unlinked stretch in Pixinsight. Later a photometric color calibration will remove it.
Dan
Posted 19 March 2023 - 02:35 PM
Dan
Thanks. I'll give it a try.
Reif
Posted 19 March 2023 - 02:40 PM
Posted 19 March 2023 - 02:49 PM
Da
Could be the matrix, same process would apply in PS, unfortunately no color calibrators are in PS that I know of... I use PI for most of my Astro Editing, but PS comes in handy often.. It's just slower for many things.
This is fastest way I know of in PS to get the basic colors sorted out, there are hundreds if not thousands of tools in PhotoShop to adjust colors, and I'm by far NOT an expert at it... PI is much simpler far less powerful program, but it's geared toward Astro imaging...
This was moving the Tint slider in Camera RAW Filter up 53... You can see your histogram change on the top, when all the colors are aligned then the colors are balanced... You can do the same thing in LIghtroom which is almost the same as the RAW filter... This was just a super quick edit to get the green back to what looks white to me... So the colors are roughly balanced, you can edit from there to taste...
Edited by Robert7980, 19 March 2023 - 03:04 PM.
Posted 19 March 2023 - 03:11 PM
I left the green in the above for a reason, balancing the green out killed the color of the Flame so I decided to leave it... One could spend time masking it off and adjusting it separately to fix that but I didn't want to spend the time on it... So the color cast from the NBZ can be a pain depending on what your shooting with it.. I should have shot that target without the filter, so I plan on going back next year and reshooting it to fix it... I still like the image even though it looks a little weird...
-Edit-
On another note... If you think about it, the colors are actually not wrong, the filter picks up Ha (red) and OIII (green) only, that's it's job... So it's pretty much as it should be, it's not a "Problem" it's just different than without the filter... It's a really good filter... So don't think less of it because it has this property....
Edited by Robert7980, 19 March 2023 - 03:18 PM.
Posted 19 March 2023 - 03:30 PM
Use SPCC and set it up with the proper settings. You’ll probably find it does a very respectable job of addressing the green bias that can be a bit stubborn on RGGB sensors. Also, OIII inherently lands somewhere in a green-blue color range, and presents with some of that green cast naturally. Some of it, though. I can tell in the stars around the Horsehead that you also have some of the green bias that usually takes a touch of fuss to calibrate out. Once you’ve calibrated it, link the channels in STF if you want to auto-stretch, as it still may want to give you a slightly green-biased stretch unlinked on account of the better signal vs noise in the green channel.
You see the stronger blues a lot because many people just kill the whole green color range with SCNR, which, overdone, actually gives a false color to OIII regions. (Which can also be a personal preference in editing.)
What is SPCC ?
I'm new to processing astrophotography.
Reif
Posted 19 March 2023 - 03:32 PM
-Edit-
Thank you Robert!
I tried camera raw and see what you mean. I think I'll leave it and just try to get it to pop more.
Thanks again ,
Reif
Posted 19 March 2023 - 03:43 PM
What is SPCC
Reif
SPCC is a tool for calibrating colors in PixInsight.. It uses data from professional observatories to match star colors so the colors are as "real" as possible... It works ok, and it's a lot of work to use... If you are planning on processing a lot of astro-photos then PI is a really nice tool. It's fairly expensive an has a bit of a learning curve but it's well worth the investment in time and money to get the most out of the expensive gear we use.
Most of the acronyms you'll see (SPCC, BXT, SCNR... ) are PI tools, the letters are easier to reference than the actual names because some get ridiculous like SPCC
Posted 19 March 2023 - 04:34 PM
Oh, I mixed up who was posting what.On another note... If you think about it, the colors are actually not wrong, the filter picks up Ha (red) and OIII (green) only, that's it's job... So it's pretty much as it should be, it's not a "Problem" it's just different than without the filter... It's a really good filter... So don't think less of it because it has this property....
Posted 19 March 2023 - 04:38 PM
As explained above, yep, a PixInsight tool, and abbreviated because some of those names are an exercise in absurdity. I mixed up a couple authors of replies above and thought you had access to PixInsight.What is SPCC
Using the tint slider increases the magenta/red while decreasing the green. Instead try using the color mixer in camera raw and decrease the green saturation level, I like this better than SCNR in PI.
Posted 19 March 2023 - 04:42 PM
Thanks.
I can't afford PI so I'll have to stick with PS.
Thanks again ,
Reif
Posted 19 March 2023 - 06:22 PM
Posted 19 March 2023 - 06:54 PM
Thank you Brian!
I'll give it a whirl
Reif
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
