Need help removing Orion xt10 collimating screw
Orion
6 replies to this topic
#1 Baldacchino
Baldacchino
Posted 21 March 2023 - 01:59 AM
My xt10 is missing a collimating knob. I cannot find a replacement and it appears Orion doesn’t have it in stock either. I know the thread size but it’s such a unique fit.
I’m order to find a knob that fits it would help if I extended the screw that the knob went on. So I removed the lower assembly, removed the mirror, and now the 3 screws seemed to be loctite secured to the cell. Does anyone have any ideas on what I can do? I’m open to ideas for knobs too or suggestion to any part of my process. I’m new and trying to fumbling around here.
Sent from my iPhone using Tapatalk
#2 Jon Isaacs
Posted 21 March 2023 - 05:31 AM
You only need two of the three collimation screws to align the primary mirror.  I recommend picking one of the three and never touching it.  That way the mirror stays in the same place in the tube. If you use all three, then you can "walk the mirror" up and down the tube.
  • Neanderthal likes this
#3 Tangent
Tangent
  • Loc: Texas
Posted 21 March 2023 - 05:37 AM
Yes, they use red thread locker on those screws because they can impinge on the mirror if they get loose.  To remove red thread locker you need to heat it up to 500F; I used a propane torch (carefully) but one of those small butane torches should also work.
#4 MellonLake
MellonLake
  • Loc: Toronto, Canada
Posted 22 March 2023 - 12:43 PM
TAKE THE MIRROR OUT FIRST
#5 MellonLake
MellonLake
Also, Bob's Knobs may have a replacement.... http://www.bobsknobs.com/
#6 Baldacchino
Baldacchino
Posted 22 March 2023 - 11:37 PM
Success. I removed the mirror. The screws required a PH3 Phillips screwdriver. I used an impact wrench on a higher setting and it came off quite easily. Thank you for the help!
  • SteveG likes this
#7 briansalomon1
briansalomon1
  • Loc: Oxnard CA
Posted 23 March 2023 - 03:57 PM
I've been using the Loctite 262 (permanent threadlock) for awhile. I've found that it sometimes isn't as permanent as the advertising suggests. Even when both parts are squeaky clean when it's applied and the parts are allowed to set up overnight, they can sometimes be disassembled using mechanical force alone.
Applying and reapplying acetone for 10 minutes or so will also weaken the bond.
Glad to hear you were able to remove the fasteners.
  • Tangent likes this
Also tagged with one or more of these keywords: Orion
