3 inch coma corrector?
Astrophotography
4 replies to this topic
#1 Suphys
Suphys
Posted 21 March 2023 - 11:27 AM
I just bought an ONTC 8" with a 3" focuser from TS. And I am consider to add a coma corrector for the imaging.
However, the length of drawer is only 3.5cm which seems not support to TV Big paracorr because it will shift focus length 73mm outwards.
May I can only use 1.0x Riccardi Design or TS-Optics NEWTON Coma Corrector 0.85x Reducer.
Is there any comparsion of them or some solution to use Big paracorr?
Su
#2 Dan_I
Dan_I
  • Loc: France
Posted 21 March 2023 - 03:44 PM
Can't you move the  mirror cell down to bring the focal plane closer to the optical axis?
#3 Suphys
Suphys
Posted 21 March 2023 - 09:07 PM
There are 3 position on the tube.
However, the shortest focus position is 154mm above the tube. +73mm will shift it to 227mm, the height of focuser is 83mm, +35mm drawer and 73mm working distance cannot satisfiy the requirement.
#4 a__l
a__l
Posted 22 March 2023 - 04:42 PM
Su
I don't think you need Big paracorr. This will significantly ruin your wallet and reduce the f ratio of your device.
If your corrector is a SharpStar 3" 0.85x (I know TS likes to rename Chinese brands) then this is a good corrector.
https://www.flickr.c...in/52758136953/
https://www.flickr.c...in/52757560731/
Table from SharpStar. I hope this helps you.
Ps Yes, I wanted to add. That the telescope on the link is not Chinese. If that and not USA. The photo was taken 40 kilometers from the metropolis.
Edited by a__l, 22 March 2023 - 05:33 PM.
#5 Suphys
Suphys
Posted 24 March 2023 - 05:50 AM
Thank you for the interesting information.
It is the first time I know TS 0.85x is made by Sharpstar.
I still have an epsilon-160ed, if I use the 0.85x cc the focus length will be too near to that.
So I think it may better for me to use 1.0x Riccardi designed. Do you know anything about it?
Best regard,
Su
Also tagged with one or more of these keywords: Astrophotography
