Hello. I am currenty trying to perfect my collimation and fix tilt in my 10" SkyWatcher 250PDS f/5.
I am curios to where exactly should the primary mirror be? Like, if you completely unscrew the lock screws for the primary mirror, you can then turn each collimation screw until the mirror basically almost touches the frame. You can move it up or down in the tube (placed vertically). My question is: to achieve a perfect adjustment, what that distance should be? Should I move it down until max and then start the collimation process from there or what?
