I have one of these and it is a great scope. If you can get the mount to work by adding the hand controller it has one particularly nice feature. It has encoders. Let me explain what that means.
On most GOTO telescopes, you lock the mount when you align it and then control its movements by the hand controller either entering a target or using the arrows. If you move the scope "by hand" or bump it, you lose your alignment and the GOTO does not work until you realign the scope.
With the Ultima 2000, once you align the scope, you can loosen the clutches and move it by hand. Then by just snugging up the clutches again, use the hand controller to find an object as if you had never moved it. It remembers where it is so to speak. I can't stress enough what a great feature this is. The Ultima 2000 also is very quiet when slewing which is a nice feature as well. It is prepared for Hyperstar which, if you want to do astrophotography makes the scope very fast and easy to use. Mine is optically very nice. As good as I have seen in an SCT.
If you want to get it running again I suggest you go easy on the motors at first. The original lube is like glue. You can open it up and do it manually to get it going or just balance the tube carefully and move it carefully at first. Why not tinker? Get a hand controller and all you are out is that and you can resell it easily.
You can defork it if you want but that mount is particularly good if you can get it going. And its a whale of a lot easier for visual than an EQ mount of any kind. For AP you can get a wedge if you want to go there. Nothing wrong with saving $1000.00 plus while you are at it.
Good luck! I'm sure it is a very nice scope.
