When I got an NEQ6 mount for a song it included a 10" F/4.7 Skywatcher 250PDS newtonian, not something I needed but hey, it was essentially free. I have the scope on the NEQ6 now but it's pretty heavy for the mount, and a tad long so manuvering it around in the micro-observatory is kind of hazardous. I would like to reduce the focal length as much as I feel capable of (not my first mirror, I've done 8" and 9" mirrors of moderate focal lengths) and reduce the tube length so it's lighter and more easily fits in the observatory.
I'd also like to increase the size of the secondary mirror and get a bit more backfocus so I can use a rotator, right now with a mono camera and filter wheel I'm pretty close to bottoming out when coming to focus. I am thinking I'd like to grind the mirror down to F/3.3 (I think this is as short as I can go without needing a Paracorr, I already have a GSO coma corrector that works well on my 16" F/4.5) and cut the tube down to about 35" from the current 50" or so. I'd also like to replace the vixen dovetail with a CGE dovetail I already have, which just requires a new adapter puck on the NEQ6.
Next step is to take the scope apart and see what the quality on the other components are to decide whether they are reusable or should be replaced.
Comments welcome! One initial question is that I want to use my ASI183MM Pro with the scope but upgrade eventually to APS-C sized sensors so I would like to illuminate an entire 23.5mm x 15.7 mm frame so choosing a secondary that does so is important. An 88mm secondary provides (per Newt) a 20.81mm 100% Illuminated Diameter which is pretty close (I still need to firm up some measurements). It's a 35% central obstruction but for an astrograph fully illuminating the sensor seems to be important, no? Any comments on designing an astrograph would be appreciated. This scope will never be used visually.
