So I've finally switched over to a NUC after using the ASIAIR Pro for over 2 years and while I'm enjoying the myriad of tools available (currently running NINA, Stellarium, SharpCap, PHD2), there is a fairly steep learning curve associated with the transition. While I do enjoy a cognitive challenge, I don't really like running into a wall over and over again and my wife would prefer if I didn't spend ALL of my free time troubleshooting software/settings/configurations... ok, to the question:
I'm working through comparing using a flats panel with NINA Flat Wizard against shooting sky flats. While I am struggling with sky flat/dynamic exposure settings which consistently work, my larger question is whether it is possible to rotate my filter wheel to a dark-slide to take the dark flats. I get a dialog to cover my scope in order to take the dark flats, but the rest of NINA interface is locked out at that time and I cannot access the filter wheel to rotate to my dark slide, which covers the sensor more fully than a cap... I'm on a 10" newtonian and there are light leaks around the base of the primary which corrupt my dark flats.
Has anyone figured out how to do this? or am I stuck with manually adding the cap and hoping it is dark enough... it never is.
edit: So far my workaround has been to let the Flat Wizard finish... cancel at the dark flats... go to my flat files and write down all the various exposures to set up a custom sequence to shoot with a dark filter at those exposures and run.... THEN go into a FITS editor script and change the filter type for each subset of DARKFLATS to the appropriate filter...it is a bit tedious to say the least.
Edited by noons, 26 March 2023 - 09:19 AM.
