SLOW MOTION CONTROLS FOR AZ100
#1
Posted 26 March 2023 - 11:51 AM
This is an outstanding mount but I am not comfortable fixing small mechanical problems. If no one else has this trouble I will contact Derek at Rowan to ask for assistance
#2
Posted 26 March 2023 - 12:55 PM
Try the damping adjusters. They are not the friction controls, they are the smaller knobs one on each side of the mount a pair each for altitude and azimuth. Turn them each time only slightly as you adjust them. I would try that before trying to adjust the worm gears, I had the same issue then discovered those dampers which solved the problem for me.
#3
Posted 26 March 2023 - 01:25 PM
You can adjust the slow motion control and backlash by adjusting screws that are marked (A) I believe in the Rowan AZ100 instructions online.
#4
Posted 26 March 2023 - 01:47 PM
If everything else fails, read the instructions. That's the way I do it.
http://rowanastronom.../AZ100Mount.pdf
#5
Posted 26 March 2023 - 02:19 PM
