Single and double stack disks from 3-26-2023
5 replies to this topic
#1 hopskipson
hopskipson
  • Loc: Queens, New Yawk, Light pollution Headquarters!
Posted 27 March 2023 - 08:08 PM
It's been a while since I was able to get some decent time and weather at the same time to image the sun.
The first is a single stack image with a Lunt LS80 and ASI174MM.  Seeing was pretty good.
This second is the LS80 double-stacked with an original Isle of Man Coronado 90 mm etalon.  I'm still working on getting the tilt just right.
The last is double-stacked with the Lunt internal double-stack unit. I think I got this pretty dialed in. Try to ignore the white framing as I tried to get the orientation right.
I was going to try for the triple-stack but the sun was lost behind some branches. Thanks for looking!
  • Skywatchr, bigdob24, rigel123 and 4 others like this
#2 Zhengyi
Zhengyi
Posted 27 March 2023 - 09:48 PM
I like the second image the best. It really shows that double-stacking with the front mounted etalon is far more superior, offering better contrast than the internal double-stack unit.
Just curious, what blocking filter are you using with the LS80 double-stacked with an original Isle of Man Coronado 90 mm etalon configuration? I'm guessing the Coronado?
  • Skywatchr likes this
#3 dhkaiser
dhkaiser
Posted 28 March 2023 - 06:15 AM
Nice comparison, however your Lunt Lunt DS is off band.  Compare SW area in band and SE off band.
  • Skywatchr, rigel123 and hopskipson like this
#4 hopskipson
hopskipson
Posted 28 March 2023 - 07:29 AM
I have such a hard time aligning the sweet spots of both etalons. At least my CP filter is working well. No glow around the limb.
  • Skywatchr and dhkaiser like this
#5 hopskipson
hopskipson
Posted 28 March 2023 - 07:30 AM
I’m actually using a Lunt 1800 that is modified for double stacking.
#6 dhkaiser
dhkaiser
Posted 28 March 2023 - 09:11 AM
I too have that trouble.  It is difficult.
