Removal of tilt and rotator on Redcat 51?
7 replies to this topic
#1 mferguson
mferguson
  • Loc: Boulder, CO
Posted 31 March 2023 - 05:09 PM
Would anyone know if it is possible to remove both tilt and the rotator from the Redcat 51?  The reason I ask is that my desired image train is 63mm and the desired back-focus range appears to between 55mm-59.7mm.
My desired imaging train would contain the following:
Pegasus Falcon rotator (19mm) + QHY OAG L (10mm)  + QHY 7 position with 2inch mounted filter wheel (21.5mm) + QHY268M (12.5mm) = 63mm
It seems that if tilt and the rotator could be removed I would gain the distance to mount this train and still have helical focus range to be able to get sharp focus.
I've seen a number of RC51-based systems with a filter wheel and OAG but none with the Falcon rotator.
Thanks for any advice and insight that you can share!
Mark
#2 PeteConrad
PeteConrad
  • Loc: Washington, DC
Posted 31 March 2023 - 08:22 PM
I have a RC51 and it can't be done. I suggest using a small guide scope instead of an OAG.
#3 mferguson
mferguson
  • Loc: Boulder, CO
Posted 31 March 2023 - 08:33 PM
That's what I've done to date.  I'm hoping to set up an imaging train so I can swap it over to C8 or C9.25 and back to the RC whenever I'm doing different targets of interest.
#4 Daniel Mounsey
Daniel Mounsey
Posted 31 March 2023 - 11:16 PM
It comes off. It's just an over engineered nightmare.
  • Mickeyemer likes this
#5 mferguson
mferguson
  • Loc: Boulder, CO
Posted 01 April 2023 - 08:28 AM
Anyone have an idea of what you find when all is removed?  Is it a threaded interface where the rotator connects to the tube or something proprietary?
#6 James Peirce
James Peirce
  • Loc: Salt Lake City, Utah, United States
Posted 01 April 2023 - 08:30 AM
Why call them over-engineered nightmares?
They’re just threaded accessories. You can remove them and explore with no concern.
#7 mferguson
mferguson
  • Loc: Boulder, CO
Posted 01 April 2023 - 05:56 PM
Excellent. Disassembly will begin and I'll see if I can make this happen :waytogo:
  • Pasko likes this
#8 Pasko
Pasko
  • Loc: Sydney, Australia
Posted 09 April 2025 - 05:13 PM
Excellent. Disassembly will begin and I'll see if I can make this happen waytogo.gif
Hi Mferguson. I was wondering if you you managed to remove the field rotator on the redcat? I am considering doing this myself. Thank you
