I'm planning to put together a short fl widefield imaging setup. I currently use a Celestron OAG with my MN190 scope which has a fl of 1000mm. My new setup will be a small refractor maybe 65 to 80mm running around at a fl of around 300-400mm. Whenever I look at similar setups, almost everyone seems to use a small guidescope instead of an OAG. I was just going to use my current OAG. But I wondered if maybe using a guidescope was actually better when shooting at a short fl. I'm thinking less weight on the focuser would be nice and a guidescope should guide perfectly fine at these short fl's. Just planning my new purchases and not sure if I should also plan on a guidescope and bracket or just repurpose my current OAG.
cs...John
