I need some insight here. When I image the Sun I do not have a full disc, which is fine for me, but perhaps that part of the issue. The issue is that I will have the sort of off center darkening of my image and I am not certain how to avoid that. I have a Lunt 100Tha, ASI533mm and 174mm and use a tilt adaptor to deal with Newton's rings, but this darkening I do not know the source of, whether it is rooted in the pressure tuning and/or the fact I am dealing with diagonal in my imaging train? I'm under the impression I need the blocking filter in even when imaging. I can generally smooth this out with auto-toning in PS, but if this is something I can fix during imagining I would like to know how. Below is an example from the other day. Notice the bottom left of the image.
Solar Imaging Question - Lunt
#1
Posted 31 March 2023 - 08:13 PM
- John_Moore, dbowlin and MalVeauX like this
#2
Posted 31 March 2023 - 08:18 PM
You're seeing uniformity issues, generally from tuning. It takes very gentle great care to get tuning just right so that the disc is uniform. It's easy to not see it at first until later you go to push contrast hard and then you notice it. So first and foremost I would suggest practicing uniformity tuning so that the live view is recognized and not just later after you process. If all else fails, until you get there, a flat calibration would have handled the brightness differences (but doesn't fix bandpass uniformity issues).
Very best,
- John_Moore likes this
#3
Posted 31 March 2023 - 08:23 PM
Wow, amazing!
#4
Posted 31 March 2023 - 08:34 PM
Very best,
So it is on the tuning, thank you for that!
- MalVeauX likes this
#5
Posted 01 April 2023 - 08:38 AM
Is that SS or Doubled stacked?
dale
