I’m a big advocate of afocal night vision astronomy. However, I’ve enjoyed having the option of using my pvs14 in prime as per this thread (I can get all my scopes to work in prime mode with this adapter including dobs and refractors)
https://www.cloudyni...ith-parts-list/
However, very shortly after this was posted, the trybe adapter was discontinued meaning that pvs14 became problematical to convert to prime again (if you didn’t already have the trybe). There were also a few aspects of the trybe adapter which I wasn’t that keen on - the clip on approach meant that there was a possibility that the adapter wasn’t square to the image intensifier and the clip on adapter did let in some light to the side which isn’t ideal if you have some light pollution.
With the help of someone on CN, I was able to provide rafcamera with a bespoke design for a screw in adapter to convert a pvs14 to prime. You need to unscrew the infinity stop on the pvs14 (which may also have some set screws that need removing with an Allen key), then the adapter screws onto the thread that is revealed. Be careful when screwing on as the threads are quite fine.
I kept the adapter short so that the front lens can be easily screwed in and out and removed as required. For prime use you need to add a 10mm t2 extension to fully clear the battery cap which I also got rafcamera to design. It needed to be as slim as possible to enable the adapter to clear the battery cap on the Carson pvs14 body. On the elbit body there is more space to the battery cap so also fine with that body.
As this adapter is screw on it eliminates the issues of the trybe adapter as well.
links to the adapter and extension tube below
https://rafcamera.co...m42x0-75f?amp=1
https://rafcamera.co...-t2m-10mm?amp=1
pics with it attached to Carson and elbit pvs14s shown below
