DPAC of an achromat - Stellarvue SV80/9D
52 replies to this topic
#1 Scott in NC
Scott in NC
    Refractor Aficionado
  • Loc: NC
Posted 15 April 2023 - 11:52 AM
We've done a lot of apochromats and ED doublets lately, so I decided to shift gears a little and show you guys what a decently well-corrected achromat looks like on DPAC.  About a month or two ago I posted some green-light DPAC images of my Stellarvue SV80/9D, an 80mm f/9.4 doublet achromat that I've owned since 2004. This scope holds a special place in my heart, as it was the first refractor that I ever purchased, and started me down this road of refractor fanaticism. grin.gif
Here's a picture of the set-up, just to show what the scope looks like. Since I last tested this scope, I've refined my photographic technique, and now use a recently acquired Canon 100mm f/2.8 macro lens, and taking the advice of one of my friends here I now use a black t-shirt as a backdrop to eliminate stray light and reflections.
  • stevew, Jeff B, lee14 and 3 others like this
#2 Scott in NC
Scott in NC
  • Loc: NC
Posted 15 April 2023 - 11:55 AM
SV80/9D in green light
Inside focus:
At focus:
Outside focus:
  • siriusandthepup, stevew, KWB and 8 others like this
#3 Scott in NC
Scott in NC
  • Loc: NC
Posted 15 April 2023 - 11:57 AM
Pretty nice in green, huh? :ubetcha:
  • Scott Beith, Erik Bakker, lee14 and 2 others like this
#4 Scott in NC
Scott in NC
  • Loc: NC
Posted 15 April 2023 - 12:00 PM
Now let's look at how colorful an achromat actually is (even a pretty well-corrected one with a relatively long focal ratio of f/9.4) compared to all the apochromats and ED doublets that we've seen lately.  White light really shows this scope's true colors (pun definitely intended!). lol.gif
Inside focus:
Outside focus:
  • Scott Beith, siriusandthepup, stevew and 11 others like this
#5 Scott in NC
Scott in NC
  • Loc: NC
Posted 15 April 2023 - 12:04 PM
One thing that these images illustrate really well is just how far apart the focal points for violet and yellow are.
I also used an image processing program called GIMP that allows me to isolate the R, G, and B channels, but can't post those here as I haven't yet figured out how to save the images.  I hadn't used GIMP in several years and am having difficulty sorting out the most recent version, so if anyone knows how to do this, any help would be greatly appreciated!
  • Jon Isaacs, russell23, lee14 and 2 others like this
#6 lee14
lee14
  • Loc: CNY
Posted 15 April 2023 - 12:16 PM
Nothing like empirical evidence to separate fact from opinion. Well done!
Lee
  • Scott in NC and Jeff B like this
#7 gstrumol
gstrumol
  • Loc: north of Detroit, Michigan USA
Posted 15 April 2023 - 01:03 PM
Perhaps I could help, Scott.
I took your colorful image into GIMP and then clicked on the colors menu. Then slide down to levels. You'll get a pop up box as shown here:
(click to enlarge)
I then went to Channel: and selected Red. Go to 'output levels', grab the little white triangle to the right and drag it all the way to the left (effectively removing the red from the image), do the same for Green. This gives you the bule only channel, as you see.
Finally go to File and Export. There you can save the image in whatever format you like!
  • Scott in NC, Skywatchr, Jeff B and 4 others like this
#8 Scott in NC
Scott in NC
  • Loc: NC
Posted 15 April 2023 - 01:08 PM
Thanks!  That’s pretty much what I did, although used another method to separate out the individual channels. When I went to save those images using the File—>Export function, it just re-saved the original white-light multi-colored version.  Maybe I need to try your method of separating out the colors?  I’ll give it another try.
#9 gstrumol
gstrumol
Posted 15 April 2023 - 01:14 PM
That will work. To do another color just click on [base image] on the left and you'll be back to the colorful image you started with. Then repeat the process to get the red (by eliminating the blue and green) and export again.
Easy peasy!
#10 CHASLX200
CHASLX200
  • Loc: Tampa area Florida
Posted 15 April 2023 - 01:28 PM
Looks ok to me. I would need to take it to 300-400x and see how a star image would look like to really know.
Edited by CHASLX200, 15 April 2023 - 01:29 PM.
#11 Scott in NC
Scott in NC
  • Loc: NC
Posted 15 April 2023 - 01:31 PM
  • stevew, Lagrange, garret and 4 others like this
#12 Scott in NC
Scott in NC
  • Loc: NC
Posted 15 April 2023 - 01:41 PM
Thanks, Gary—that worked!  Apparently the method I used was just a way of viewing the isolated channels but not a method of actually changing the image itself in a manner that can be saved.
  • gstrumol likes this
#13 gstrumol
gstrumol
Posted 15 April 2023 - 01:44 PM
Happy to help!
  • Scott in NC likes this
#14 Echolight
Echolight
  • Loc: Texas
Posted 15 April 2023 - 01:47 PM
Looks well figured at least. Even with the "chromatic blur", likely sharper than a butter knife.
#15 Scott in NC
Scott in NC
  • Loc: NC
Posted 15 April 2023 - 01:54 PM
With Gary's help (thanks again!) I've learned how to save and post the individual color channels after extracting them with GIMP.
First red.
Inside focus:
Outside focus:
  • Terra Nova and Ben the Ignorant like this
#16 Scott in NC
Scott in NC
  • Loc: NC
Posted 15 April 2023 - 01:55 PM
Now green.
Inside focus:
Outside focus:
#17 Scott in NC
Scott in NC
  • Loc: NC
Posted 15 April 2023 - 01:57 PM
And last blue.
Inside focus:
Outside focus:
#18 Scott in NC
Scott in NC
  • Loc: NC
I've got to run to get some lunch right now, but will be back a little later with some commentary.
#19 Scott in NC
Scott in NC
  • Loc: NC
Posted 15 April 2023 - 02:20 PM
Red and green are reasonably close together in focus, and blue is much farther out.  You can tell this because when those colors are isolated from the white-light image, the red/green banding looks pretty similar, but blue has a greater number of bands in the inside-focus image and a lesser number of bands in the outside-focus image, when compared to red and green.  This is so because the major determinant of how many bands you see in the Ronchi image is how close you are to focus.  The farther from focus, the greater the number of bands, and the closer to focus, the fewer the number of bands.
And the short version for those who'd rather not read all the gobbledegook above: Achromats have significantly different focal points for the various wavelengths of light compared to apochromats. Not that you all didn't already know that, but sometimes it's nice to see it illustrated. grin.gif
  • Scott Beith, Erik Bakker, russell23 and 2 others like this
#20 Scott in NC
Scott in NC
  • Loc: NC
Posted 15 April 2023 - 02:50 PM
Spherical correction looks pretty good in all colors (especially green), considering this is an inexpensive achromat produced nearly 20 years ago. Interestingly, I see a minor edge abnormality which doesn't really show up in the images shot in green light, but does show up in the image shot in white light, with the green channel extracted via image processing.  See here:
Green light Ronchigram:
White light Ronchigram with green channel extracted:
Anyone have any ideas as to why this might be?
  • Erik Bakker, Terra Nova and CreatorsHand like this
#21 scout
scout
  • Loc: Mount Diablo, CA
Posted 15 April 2023 - 03:49 PM
Haha, no matter what the topic, Chas has to add how he uses physics-defying magnifications with a 0.1 exit pupil.
#22 CreatorsHand
CreatorsHand
  • Loc: Marquette, Michigan
Posted 15 April 2023 - 03:58 PM
It looks to me like the minor edge abnormality is still there in the green LED Ronchigram, but the image is dimmer so it isn't as visible. You might try increasing the brightness of the green LED image; you may find the edge abnormality shows up better.
#23 CHASLX200
CHASLX200
Posted 15 April 2023 - 04:32 PM
I always use crazy powers on any scope to see how far i can go. Sloppy optics won't cut it.
  • Skywatchr and Mph100 like this
#24 Scott in NC
Scott in NC
  • Loc: NC
Posted 15 April 2023 - 05:45 PM
Yeah, okay, but what I’m trying to show here is something that I can actually do on planet Earth, day or night, no matter what the weather. I’m glad that you have perfect skies most of the time, but I can’t hop on a plane with a scope and travel to your house every time I want to test out a scope.  You clearly don’t need to do DPAC testing, Chas, but I’m trying to let the other 99.9999999875% (that’s 1 minus (1 divided by 8 billion), multiplied by 100 to turn it into a percentage) of the world know an alternative way to evaluate a scope.
#25 CHASLX200
CHASLX200
Posted 15 April 2023 - 05:50 PM
I would love to sky test scopes that i can see a DPAC on and compare.
  • Scott in NC and Skywatchr like this
