OpenLiveStacker - 4th beta - Android Stability Fixes
49 replies to this topic
#1 artik
artik
  • Loc: Israel
Posted 20 April 2023 - 01:27 PM
OpenLiveStacker - is an open source application for live stacking for Linux and Android.
Background
I'm getting into EAA, but the big stopper for me is a cumbersome setup and one of big inconveniences is need to bring a laptop to control the camera and do the live stacking and even more so as Linux user I don't really have viable solution even if I bring a laptop. Since we all have quite powerful computing device smartphone or tablet, if I only could connect an astronomical camera directly to a smartphone or tablet...
So I implemented it and released as open source... (my two hobbies open-source software and astronomy connected)
229337011-72031279-8de8-4be0-b1a1-61d592
In the nutshell
Beta 4 release Chanegelog
  • Android - fixed major issue with stability of background processing of the application.
    • Now a notification that shows that OLS is active is always shown as notification
    • Process does not exits while working in background.
    • fixed exiting from the application
  • Fixed UI issue with camera parameters settings - added button with clear way to submit new value
  • Added support of plate solving for stacked frames in addition to live frames
  • Added information of how much to move in RA/DE & Alt/Az coordinates to make accurate corrections of location after plate solving
  • Added support of discarding stacked result in case we don't want to keep it
  • Some UI code refactoring
Help I need
It is open source project build and I need your help to test and validate it even if you are ShapCap or ASIAir fan.
I need user inputs
Edited by artik, 20 April 2023 - 01:33 PM.
  • lambermo, Coco and CltFlyboy like this
#2 han.k
han.k
    ASTAP Software
  • Loc: the Netherlands
Posted 20 April 2023 - 04:32 PM
That is very interesting. Using an external camera connected to a Android table or phone will work much better then using the internal phone camera.
Which external cameras would be compatible and could be connected to an Android phone?
Han
#3 artik
artik
  • Loc: Israel
Posted 20 April 2023 - 11:38 PM
Currently following are supported
- ASI ZWO since there is an official Android sdk
- Cameras that support standard USB video class protocol, for example svbony sv105 or Webcam
I think it would be possible to add some DLSRs. I found some open source libraries that allow access to them
#4 han.k
han.k
    ASTAP Software
Posted 21 April 2023 - 03:09 AM
Then it could work with my ASI1600 camera . To connect it, I will  need to connect the ASI1600 USB3.0 type B receptacle/female with my phone. I have ordered an "USB 2.0 female to female" adapter to connect two available cables. Hopefully that will work and communicate. I will know in a few days smile.gif
In principle if your phone/tablet has an excellent camera you could use that camera instead. For solving I have noticed that the phone camera has to be of really excellent quality allowing it to be solved. But it would be to at least nice to have a menu option to select an stored image for testing.
1) Is the simulated image solvable and if so which parameters are required for solving?
2) At which location is the simulated image stored, so i could replace it?
3) Is the image processing 8 or 16bit?
Han
#5 artik
artik
  • Loc: Israel
Posted 21 April 2023 - 04:43 AM
yes it is solvable.
it is m44 object. Pixel 3.75um focal length 400mm
It is internal app cache. I'm not sure where exactly. I'll check
Stacker itself works with 32bit float data. Final result saved 16bit unstretched tiff and 8bit stretched jpeg
#6 han.k
han.k
    ASTAP Software
Posted 21 April 2023 - 04:13 PM
I tried to solve and get this error:
The path exists. It contains some log files and an ols_astap_input.tiff. The tiff file is the M44 image.
Edited by han.k, 21 April 2023 - 04:14 PM.
#7 artik
artik
  • Loc: Israel
Posted 21 April 2023 - 10:21 PM
What platform/device are you running the app?
I get this message when I try to run it in Android simulator (x86) for simple reason - there is no Android build of ASTAP for x86 or x86_64. only arm64-v8a and I assume for armeabi-v7a (32bit version as published on https://www.hnsky.org/astap.htm )
All devices I have are 64bit arm64-v8a. If you are running it on armeabi-v7a device - maybe there is a problem with astap_cli build for this arch (I didn't build it myself I downloaded it).
Edited by artik, 21 April 2023 - 10:38 PM.
#8 han.k
han.k
    ASTAP Software
Posted 24 April 2023 - 02:51 AM
Good. It work again.
1) Stacking using simulation seems to work.
2) There seems a mix up between .txt and .tiff for the stacking see attached screenshot
3) The thelables of the menus are not displayed correctly. See screenshot. Screen is not wide enough
4) Solving still fails. There is no database at
    /storage/emulated/0/DCIM/OpenLiveStacker/db
Logs, See zip file.
Han
#9 han.k
han.k
    ASTAP Software
Posted 24 April 2023 - 03:05 AM
What I don't understand, from my laptop I can't see the screenshots at /DCIM/screenshots. I have first t copy them to Download.
This is the message after a solve instruction. It looks like astap_cli is not executed. see screenshot.
Probably it would help it to add some temporary checks in a debug version of your program. First to check that the executable is in place. Secondly if the database is in place. Then thirdly what error is generated if astap_cli is executed.
#10 artik
artik
  • Loc: Israel
Posted 24 April 2023 - 04:12 AM
tiff - unstratched 16 bit tiff if you want to do post processing
jpeg - stretched 8 bit jpeg - stuff you see on the screen
txt - general information about the result
(I need to add gallery of results)
It looks like what is not working is running exe. Linker itself runs (so exe succeeeds)
/system/bin/linker64 /data/app/dom.domain-9bTGef9SpwsKheSjRHdanQ==/lib/arm64/libastap_cli.so -f /storage/emulated/0/DCIM/OpenLiveStacker/debug/ols_astap_input.tiff -fov 0.559000 -ra 8.672778 -spd 109.677778 -r 5.000000 -o /storage/emulated/0/DCIM/OpenLiveStacker/debug/ols_astap_output -d /storage/emulated/0/DCIM/OpenLiveStacker/db
But fails to run the libastap_cli.so,
the executable is actually present (I added a check) - it is one of stuff I was worried about.
Since running (linker) succeed I look for the result file I miss
I actually do. That is why I don't even check for DB because astap_cli reports me if DB is missing on results file.
Unfortunatly astap_cli wasn't executed.
I'll try one again to run simulation of arm64 to check on Android 8.
How hard for your to build x86 or x86_64 version of astap_cli for Android?
The problem is I can run different versions of Android under simulator but arm64 simulation is painfully slow and for some reason does not work. My Android 8/arm64-v8a simulator does run for some reason.
Another thing I can try is to skip linker and run it directly. Maybe it would run on older Android OS versions?
#11 han.k
han.k
    ASTAP Software
Posted 24 April 2023 - 05:19 AM
Very easy. I cross compile under Linux. So I just tell the compiler to compile an Android executable and that's all. So currently with one script file it compile all executables for Windows arm, Linux X86, arm, Mac X86 & arm. The Windows versions I compile under Windows but that could be done under Linux as well. Normally I work under Windows. Linux is running  in a virtual machine running under Windows.
I'm not very familiar with Android. Yesterday as a test I copied an astap_cli to my phone and try to execute it. But I can't execute it on my current phone. Using linker64 didn't work either. The phone is not rooted so maybe that is the reason why. I could root it but that would be not a good test.  Missing is a kind of "sudo" command like in Linux.
I will try it again on my old 32 bit phone as an exercise.
This is unclear for me.
#12 artik
artik
  • Loc: Israel
Posted 24 April 2023 - 06:41 AM
After some reading I start getting some ideas
Linker is needed because the "interpreter" set incorrectly for some reason
readelf --string-dump=.interp  astap_cli gives libdl.so while under android is should be /system/bin/linker64 or /system/bin/linker
This stuff I can edit with patchelf
This is probably the reason need to start exe via linker and not directly (also I've seen it there)
Now 2nd question if there is a need of libdl.so and it exists on Android 8. Can you check via termux (if you have one) if there is /system/lib64/libdl.so or /system/lib/libdl.so?
Edited by artik, 24 April 2023 - 06:46 AM.
#13 han.k
han.k
    ASTAP Software
Posted 24 April 2023 - 06:49 AM
I noted it is very difficult to execute files in modern Android.
https://stackoverflo...-data-local-tmp
This file exist:
#14 artik
artik
  • Loc: Israel
Posted 24 April 2023 - 07:10 AM
This file exist:
I followed this link before: and these options turned on and astap_cli was renamed to libastap_cli.so and this is how I managed to run. It probably has something to do with older Android 8.
It runs via linker under Android 10 and Android 11 without issue.
IIRC managed to reproduce the issue of astap not running once under Android 8/arm64-v8a - but since than something broken and I fail to start arm64 simulator.
Edited by artik, 24 April 2023 - 07:12 AM.
#15 artik
artik
  • Loc: Israel
Posted 24 April 2023 - 04:09 PM
Ok I reporduced it on simulator for Android 7 and armeabi-v7a (the only one that didn't crash and had working browser in image)
Once I changed interpreter in ELF to correct one
patchelf --set-interpreter /system/bin/linker ./app/src/main/jniLibs/armeabi-v7a/libastap_cli.so
Instead of libdl.so and removed exec via linker all started working.
I'll write a full fix and check on latest android on arm64 to see if it works and update APK...
BTW I tried to cross compile astap_cli myself but I couldn't find proper cross compiler for android. I though of exporting some symbols and making shared object for loading.
But I think exe is better solution at this point.
Edited by artik, 24 April 2023 - 04:09 PM.
#16 han.k
han.k
    ASTAP Software
Posted 24 April 2023 - 05:06 PM
Good, reads like your making good progress.
Compiling astap_cli. From Lazarus (at least in Linux) you can compile to any system if an compiler is installed for that system.  Easiest is to use fpcupdeluxe which you can use to install Lazarus and all compiler you want including Android:
https://github.com/L...ses/tag/v2.2.0r
Once installed including cross compiler for Android, you just have to load the file below in Lazarus and compile:
astap_command_line_android_arm64.lpi
or use the command line compiler. Something like this:
/home/h/fpcupdeluxe/lazarus/lazbuild   astap_command_line_android_arm64.lpi
I'm not sure if it is possible to make a share object.
  • artik likes this
#17 han.k
han.k
    ASTAP Software
Posted 25 April 2023 - 10:40 AM
Today the OTG cable arrived. Finally the stream works for my ASI1600:
Saving settings values like camera gain and exposure time would be very beneficial.
You could add to the tiff some information to make it Astro-TIFF like celestial position, exposure time.
The pixels in the stack file have all value zero, so that doesn't work for me yet
Probably it is better to move the discussion to GitHub or to a personal message discussion.
Edited by han.k, 25 April 2023 - 03:21 PM.
#18 artik
artik
  • Loc: Israel
Posted 25 April 2023 - 02:53 PM
1st of all good news..
2nd I released fix for ASTAP on android 7-8 and notification bug fix as well
https://github.com/a...eases/tag/beta5
Can you please check that ASTAP works as expected/
Now from what I understand it is Mono camera. Since I hadn't had a chance to test it on mono (I own only SVBony sv105 and ASI ZWO 224mc) - there are likely bugs so I'll continue discussion over github
3rd... The UI is horrible what browser are you using? Something clearly wrong with positioning.
Edited by artik, 25 April 2023 - 02:54 PM.
#19 han.k
han.k
    ASTAP Software
Posted 25 April 2023 - 03:32 PM
Samsung browser
Solver is now executed laugh.gif , but database is not found.
Will continue here:
https://github.com/a...eStacker/issues
#20 han.k
han.k
    ASTAP Software
Posted 25 April 2023 - 05:24 PM
Here a screenshot of the stacking but still some problems:
#21 artik
artik
  • Loc: Israel
Posted 25 April 2023 - 09:06 PM
Samsung browser
Will continue here:
Actually this one is simple: https://github.com/a...olver-on-andoid
Just download and unpack
#22 artik
artik
  • Loc: Israel
Posted 25 April 2023 - 09:07 PM
How it looks like in landscape mode?
Generally in landscape orientation I expect it to work better
#23 han.k
han.k
    ASTAP Software
Posted 26 April 2023 - 02:00 AM
In landscape it looks similar. Vertical it is worse. See attached
If the .ini is not found it would be helpful to have an app warning with the instruction to unpack the database at that location. The current message looks like an app failure and not like an installation problem.
Edited by han.k, 26 April 2023 - 02:00 AM.
#24 daw316
daw316
Posted 26 April 2023 - 06:59 AM
Please keep discussion (or a copy) here.
  • UB_Astro likes this
#25 artik
artik
  • Loc: Israel
Posted 26 April 2023 - 08:04 AM
Summary: https://github.com/a...eStacker/issues
  1. Improve settings - save pixel size/FL, handle presets.
  2. Full frame ASI 1600 can be harsh on handheld device live stacking (in terms of workload) but likely going to be ok for 2x2 binning.
  3. Some ideas on improving plate-solving navigation directions
Bottom line there is a work to do (as always)
And I desperately need somebody with real UI/UX web-frontend development experience to help. (I'm math, algorithms, C++, high performance computing and and web-backend guy - less of frontend/ui)
