Nice, Jeff—a very enjoyable read. Hope you get a chance to enjoy this scope under the stars tonight! I’m eagerly awaiting the star test results, and will be very interested to hear how that aligns with your DPAC findings.
Thanks Scott, and speaking of the star testing aligning with the DPAC data, yes it does.
That's the short story version, and as I've said in the past..just yesterday actually... I'm not very good at that.
The scope came out of a cool basement so it was actually warming up at first. It is a perfect fit up to my trusty AP Mach 1. The OTA was quite "lite weight" and an easy lift into the rings for this old guy. Once installed, about a couple of hours before sunset, I just had to slew over to Venus. Surprise number one was that the seeing was very steady despite, or maybe because of, the high thin clouds. Surprise number two came from the lack of terrible color error bordering the planet. I know, I know, even my achromats will not show much "CA" around Venus during the day as the sky brightness does a good job of hiding it, but the body of the planet usually shows a mild purple tint. The SW 150ED showed a very white disk and it was sharp at 110x. Cranking up the power to 164x still showed a sharp disk but also a slightly ruddy tint to the globe. But the scope was still warming up too.
I parked the scope to present a minimum profile to the setting sun, did some yardwork, shanked a couple of short wedge shots, grumbled about that and had some dinner.
About 15 minutes before sunset I got "serious". The scope had been in shadow for over an hour, the ambient temperature had dropped a degree or two and, around here, the upper atmosphere was calm. I used my AP 2" diagonal and I broke two star testing rules right up front my using my TV 3x and Silver Top 2x barlows along with my 22mm & 10mm Silver Top Plossl, old 12mm Celestron Ortho and went crazy with my 7mm UO volcano top ortho. All viewing was boring old cyclops vision. I used a trick Roland taught me years...ok....decades... ago, of putting a deep green filter over the eyepiece eye lens to isolate green.
Venus, though much brighter and in much higher contrast against the sky was still quite white. However, a blue/ruddy border was seen. The image was quite sharp though. Best, most pleasant, views were at 164x and 200x. Really very nice and I could talk myself into seeing shadings in the clouds.
Chosen stars were Pollux, Procyon and Castor. I started with Pollux at 164x and it became instantly apparent that I could go much higher in power and this was a very nice sample. Boom, right up to 300x. The airy disk at focus was slightly ruddy/orange, round and surrounded by a 360 degree ruddy first ring with very faint second ring. No Coma at all and no astigmatism was seen, even on the way to focus. Hanging the green filter in front of the eyepiece and just barley touching up focus, showed a nice round airy disk and just a single, dimmer 360 first ring. Going crazy at 514x, the atmosphere was intruding much more but I got basically the same result.
Ditto Procyon but with a more yellow tint to the airy disk with a more white first ring. Ditto to Pollux with the green filter but I also could see no meaningful differences on either side of focus close in, with the rings smoothly shrinking down to focus and then smoothly expanding out the other side. I was also surprised to not find or catch out that center "pimple" just inside/outside of focus.
Castor was just beautiful! Really rather white with a blue tint. Overall, the prettiest views were at 200x and 240x.
So, star testing was just superb really.
Jeff
Edited by Jeff B, 06 May 2023 - 09:04 PM.
