Yup, a second sample, again, snagged off of the open range . I couldn't resist and this does help to address the usual comment(s) concerning sample of one testing.
The testing and evaluation of the first sample are documented here:
https://www.cloudyni...c-test-sw150ed/
This SW150ED has a nice Moonlite 2" focuser, which is sooo much better than the stock focuser, with an excellent visual back and was nicely collimated with the center of the objective, requiring just a small tweak for perfection. The focuser does not have the internal glare stops that the stock focuser has (and none are needed as stray light suppression is excellent), resulting in a much larger fully illuminated FOV over stock. The ML focuser also has a much shorter length than the stock focuser and transition piece assembly, making it bino-friendly with all of my bino-viewers when using my Baader BBHS silver diagonal. An excellent upgrade.
The stock rings were the only accessories included, which, again, suites me just fine.
I wish would have checked the alignment of the objective with my Cheshire eyepiece like I usually do but I was anxious to do the star testing with the excellent seeing. The star test was horrible, showing at least one wave of astigmatism, easily seen even at low power. I was quite taken aback especially considering the truly excellent results from my first test sample. Subsequent checking of the objective with the Cheshire showed the two dots from the reflections off of the rear facing lens elements were way off from the image of the Cheshire aperture dot. I was major bummed.
Then I started thinking about it. The image seemed to be pure astigmatism, nothing else. Astigmatism is the dominant off axis aberration in most refractors. I also noticed that panning an out of focus star image over to the edge of the FOV of my 7mm UO ortho, resulted in no astigmatism. The native astigmatism of the ortho at the field edge was cancelling the objective's astigmatism. So, I was certain the lens cell was cocked off axis on the tube. The problem is, there is no provision for cell collimation adjustment with this design. I was discouraged but then I had a closer look at the end of the cell that threads on to the tube and could see a "reveal" of a couple of tube threads that was uneven around the perimeter of the tube suggesting the cell was cross threaded on to the tube. Examination of the other 150ED sample showed no such condition.
Sure enough, using my strap wrench to back the cell off of the tube confirmed the cross threading and subsequent cocking of the cell on the tube. The threads, while accurately machined, have a rather coarse pitch, which allows easy cross threading of the tube and lens cell. Once the cell was properly assembled to the tube, the astigmatism promptly disappeared, even at 340x. In fact, the subsequent star tests of Pollux, Castor and Procyon at high power with/without a green filter were excellent, perhaps a bit under corrected with ~1/6 or 1/7 th wave of coma that dissolved over time as the scope settled out thermally.
All of this is backed up with the DPAC testing.
First the green LED and white light images.
It's getting late and I'll comment tomorrow, but have a go at it if you wish.
Jeff
Edited by Jeff B, 13 May 2023 - 11:51 PM.
