HEQ5 - counterweight or shaft extension
10 replies to this topic
#1 ValeRyo
ValeRyo
Posted 26 May 2023 - 09:29 AM
I own a HEQ5 with rowan mod and my scope is a TS 150/600. The whole, with camera, guidescope and all, weights about 7kg and for balancing it, as I have only the two 5kg weights of the mount, I have to put a weight nearly all down the rod and the second to the very top of the rod. Is this a good solution? I think that a shaft extension would allow me to use only one 5kg weight at a lower point, but I read this can be not the best for guiding. The guide in this situation with two 5 kg wights is constantly at 0.8, my rig is at 1,64. What is the best solution?
- one 5 kg weight with shaft extension
- two 5 kg weight in actual position, one top one nearly down
- source a 1-2kg weight and change the 5 kg on top
Thanks!!!
#2 norvegicus
norvegicus
  • Loc: en route
Posted 26 May 2023 - 10:22 AM
Put the two weights together and slide them up and down as a unit until you are balanced.  Closer is better.
#3 f430
f430
  • Loc: La Mesa, CA.
Posted 26 May 2023 - 10:40 AM
As above, both weights together, closer to the top is best.
Edited by f430, 26 May 2023 - 10:47 AM.
#4 Devonshire
Devonshire
  • Loc: S/W Ontario, Canada
Posted 26 May 2023 - 01:36 PM
Here's a useful reference.  Made quite a difference to my mount.
https://www.astro-ph...ize-guiding.pdf
#5 Skywatchr
Skywatchr
  • Loc: North-Central Pa.
Posted 26 May 2023 - 02:46 PM
It's too bad MalwareBytes flagged this link as a phishing scam.  Strange that it would unless there is some sort of redirect/intercept going on.  I have been to the Astro Physics site before with no issues.
#6 Devonshire
Devonshire
Posted 26 May 2023 - 03:02 PM
Gosh!  My Norton is fine with it.
  • Skywatchr likes this
#7 norvegicus
norvegicus
  • Loc: en route
Posted 26 May 2023 - 03:18 PM
I have Malwarebytes too.  No issue here, site loaded fine.
#8 f430
f430
  • Loc: La Mesa, CA.
Posted 26 May 2023 - 08:36 PM
Loads fine on my Windows 10 machine.
#9 ValeRyo
ValeRyo
Posted Yesterday, 02:50 PM
thank you for all your answers!!!
#10 Skywatchr
Skywatchr
Posted Yesterday, 07:14 PM
Win10 on this PC too.  question.gif  I don't know, could be a false alarm too.
#11 Skywatchr
Skywatchr
Posted Yesterday, 07:19 PM
I dumped that major resource hog long ago. It was missing stuff others were catching anyways. It used to be the best at one time.  McAfee no longer infests this PC either.  It was just as bad.  But like I said I had been to the site many times before with no flags being tossed up. undecided.gif
