How to get started with my 150 reflector
Solar
2 replies to this topic
#1 drillepind42
drillepind42
Posted 26 May 2023 - 01:14 PM
I have a 150mm SkyWatcher explorer I would like to use for solar observations. I live quite north, so not many dark hours during the night in the summer.
How do I get started with making solar observations safely with my telescope?
My thoughts are to get a mounted foil filter like these: https://www.astrosho...ers/15_15_40_20
to put in the front of the telescope. But can I additionally include an H-alpha filter at the eye piece, to make H-alpha observations?
Any other things that could come in handy in this new exciting field?
#2 MalVeauX
MalVeauX
  • Loc: Florida
Posted 26 May 2023 - 01:20 PM
One of those Astrozap or Baader pre-made solar film cells would be fine (ND5.0 is visually safe). You could get one for the full aperture at 150mm and be ok. Just use low magnification when seeing is really poor. Consider green to red wavelength filters to handle seeing.
To make your newtonian work with h-alpha you would need an expensive etalon filter system and it would require energy rejection since it has obstructions (your newt's secondary) and since mirrors absorb heat and do not fully transmit all the energy. This is also expensive. It would be more difficult and costly to turn your 150mm newtonian into an h-alpha chromosphere capable instrument than it would be to simply get a small 60~80mm refractor and an h-alpha system for it (or a dedicated smaller instrument).
Night time h-alpha filters do not show you the chromosphere, they're too wide bandpass and will only show you the photosphere. To see the chromosphere you really need to be less than 1 angstrom bandpass (0.1nm). So 3nm, 7nm, 12nm, or more is too wide. It needs to be down below 0.1nm. This is why etalons are used.
Check out the forum stickies to get more information on etalons and why all of this is needed.
Very best,
  • Skywatchr likes this
#3 drillepind42
drillepind42
Posted 26 May 2023 - 01:35 PM
I see. Didn't know that the night-time H-alpha filters were different, but it makes sense due to possible redshifts further away I guess, to make the bandpass a bit wider.
I will check out the stickies. Stille new to the site, so thanks for pointing me in that direction. Will be fun to try the relative inexpensive solar films before investing in a dedicated instrument.
Also tagged with one or more of these keywords: Solar
