Okay, sorry to be a thicko, but I'm running around in circles trying to find a workable version of this and hitting lots of dead links, or not being able to find textures (higher res) or getting the terminator line drawn but not getting the shadows to show.
On Fri 26th May about 2200 UT I looked at the Moon telescopically for the first time in ages. I've heard of lunar X and the like, but what I saw distinctly beyond the terminator where three lunar colons, : , and I don't remember having caught anything like that before. they looked like little even doubles stars floating next to the bright end of the Moon, but then you'd have to be able to see through the Moon ;)
Take two halves of the Moon, top and bottom half (as inverted in a 216mm reflector, Moon not far past Central Meridian (that is, not long past having transited), haflway along the 'top' half was a nice close pair, halfway along the bottom half was a nice close pair and I think I've candidated a pair of Mons for that one (that two, properly). And actually halfway from lunar cusp to lunar cusp was a nearer to the terminator, nearer to each other, and a fair bit fainter but still equal brightness pair. Possibly highpoints on crater rims, or a highpoint on a crater rim and a central peak's tip, or whatever.
Anyway, would like to emulate the experience, it's supposed to be LTVT I believe that is used for this, but although I found a live link for version 0.21 which led to github, I can't find any of the textures. the VMA ones don't seem to have a "hires.jpg" and no matter what I do the shadows aren't shown, and there are so few options in the software anyway to do things. It came with lores, so I suppose it doesn't map shadows at low resolution.
I've got the docs, and there is always an rtfm case, but I've look at the getting started bit, and I've pressed the texture button a lot, with several changes in settings as possible, and stuf fall happens, bar the appearance and disappearance of the red and blue terminator lines, oh and I can get dots to pop up.
I think I'm possibly jargon challenged here and not understanding what I'm looking at. Possibly I need a DEM vertical relief file for it to know how to do shadows? The download I found just came as a 6.3 Mb zipfile.
Thanks in advance.
