Servocat alt and az reversed on hand controller
3 replies to this topic
#1 Darren Drake
Darren Drake
  • Loc: Chicagoland
Posted 29 May 2023 - 07:31 PM
After dealing with a blown fuse and totally disconnecting all the cables and reconnecting them to the servocat box the alt and az commands are reversed on the hand controller.   I believe everything is reconnected correctly, but still this has happened.  Is there an easy way to get this right such as reprogramming the hand controller or something?  Thanks.
#2 Darren Drake
Darren Drake
  • Loc: Chicagoland
Posted 29 May 2023 - 08:05 PM
I also just confirmed that the gotos are all wacky now.  Is it possible for the servocat box to loose its programing if a fuse in the box is disconnected?  I suspect not but am still uncertain...
#3 a__l
a__l
Posted 29 May 2023 - 08:55 PM
I think you've got the cables mixed up. Check the two cables that go from the Az motor to the Az sockets ServoCat and respectively to Alt.
Edited by a__l, 29 May 2023 - 08:58 PM.
#4 Darren Drake
Darren Drake
  • Loc: Chicagoland
Posted 29 May 2023 - 09:27 PM
Yes it seems you're correct!  I had 2 pair of connectors reversed and it should be good now.  There are 8 connections attached to this thing.  Years ago I labeled every connection but they all fell off or faded.  Will take care of that soon so this doesn't happen again.  Thanks.
Edited by Darren Drake, 29 May 2023 - 09:40 PM.
