Swapping UV/IR cut window for AR window on ZWO planetary camera?
3 replies to this topic
#1 neovenator1
neovenator1
Posted 02 June 2023 - 02:49 AM
Hello all. This is my first time posting on this site.
I use an asi178mc for planetary and lunar imaging. The glass which protects the sensor on this camera is uv/ir cut, meaning I cannot do any infrared imaging because the infrared is filtered out. I would like to be able to use various red and infrared filters, particularly for lunar imaging.
I’ve heard that it’s possible to remove this glass and swap it for anti-reflective glass which doesn’t filter out anything, and I’ve seen this glass available to buy from ZWO. Regarding this I have two questions:
Firstly, will I actually be able to do IR imaging if I simply replace the filter with AR glass and use IR pass filters? Like any other IR-sensitive planetary camera? If it’s so simple then why did the camera need to come with a uv/ir cut in the first place?
Second, how am I supposed to go about replacing it? I’ve searched far and wide and I can’t seem to find any tutorials or descriptions of how the glass is removed and the new glass fitted in. I’d like to understand the process of swapping the glass before I buy it.
Thanks.
Edited by frank5817, 03 June 2023 - 12:19 PM.
image resized
#2 dcaponeii
dcaponeii
  • Loc: Waxahachie, TX
Posted 03 June 2023 - 11:23 AM
Thanks.
It takes some hunting but ZWO does have photo directions for changing the windows on their planetary cameras. Yes if you us the AR window then an IR Pass filter gets you there. The AR window is still a problem for UV imaging though, as I understand it.
#3 RMay
RMay
  • Loc: NorCal
Posted 03 June 2023 - 08:00 PM
Welcome, and clear skies to you…
Ron
#4 DirtyRod
DirtyRod
  • Loc: Arizona
Posted 03 June 2023 - 09:38 PM
Easy to change the window. As mentioned, ZWO and Agena Astro sell both the windows. I’ve swapped windows on ZWO cameras a few times.
