Celestron Hα-Hβ-OIII Imaging Filter for RASA 8 ?
5 replies to this topic
#1 gmalin
gmalin
Posted 02 June 2023 - 05:00 AM
I recently imaged the Crescent Nebula with conditions as follows :
- RASA8 w/ uncooled ASI183MC
- gain 120
- 75 X 20 s (25 mn total), 11 flats, 50 darks, 50 offsets
- no filter (not even UV/IR cut)
- Moon : 43%
- North of France, Bortle 5
- Processed w/ Siril + Gimp
As shown below, the nebula has a very low contrast, so I wonder if the use of a Celestron filter #93619 "Hα-Hβ-OIII Imaging Filter for RASA 8" could improve things ?
This #93619 replaces the RASA 8 optical window, and Celestron says in its manual that this allows to maintain optical performance, as no extra piece of glass is added to the optical system.
Does anybody have some experience with this filter ?
Thanks !
  • joshua_vise likes this
#2 rob1986
rob1986
Posted 02 June 2023 - 07:24 AM
Thsts a really wide fov.
#3 licho52
licho52
Posted 02 June 2023 - 10:07 AM
It's a Rasa8, that's how it gets all that "speed" - it's wide and not diffraction limited.
#4 andysea
andysea
  • Loc: Seattle, WA
Posted 02 June 2023 - 12:14 PM
It should increase contrast considerably as it appears to be a tri-band narrowband filter. Assuming that it works as advertised, that is a really good price for such a filter. I wonder what is the bandpass. I had very good results with the 12nm Astronomic filters when I had the rasa but I was using a mono camera, so I had to shoot each channel separately.
#5 rob1986
rob1986
Posted 03 June 2023 - 12:45 PM
I know, but it would seem to me that this target might benefit from a longer fl.
#6 gmalin
gmalin
Posted 23 July 2023 - 05:39 AM
I was unable to find anyone with first-hand experience with this Celestron filter #93619 "Hα-Hβ-OIII for RASA8, but in the end I bought it anyway.
Here is an image taken with the filter, almost in the same conditions as the one I originally posted (same place, same RASA8, same ASI183MC camera, two months later...)
As you expected, the filter definitely increases the contrast on this nebula, so I'm quite satisfied with it, thank you for your advice.
