White light images from Dunedin NZ
2 replies to this topic
#1 larrytOMC200
larrytOMC200
  • Loc: New Zealand
Posted 04 June 2023 - 04:56 AM
Hi All,
             Here  are some white light shots I obtained with my 4 inch refractor. The so called Wilson effect can be seen on spots near the apparent limb of the sun. Clicking on the images should give a bigger scale. Regards Larry
  • BYoesle, bigdob24, MVoltae and 2 others like this
#2 rigel123
rigel123
  • Loc: SW Ohio
Posted 05 June 2023 - 05:51 AM
Nice shots Larry, you might try backing off the sharpening a tad to reduce the artifacts that can be produced such as the bright line on the limb and around the spots.
#3 larrytOMC200
larrytOMC200
  • Loc: New Zealand
Posted 06 June 2023 - 01:23 AM
Ah,
      I wondered what that was, I will try and be more circumspect when sharpening my images. Thank you so much for the advice. Some more images obtained today, some already saved, others to be completed. I suspect you will note the difference between the ones processed prior to me reading your comments and the ones afterwards.
(I cannot save the AVI files as it fills up my memory on my lap top too much).  Regards  Larry
  • rigel123 likes this
