AstroHopper 1.0.10 Released
42 replies to this topic
#1 artik
artik
  • Freeware Developers
  • Loc: Israel
Posted 05 June 2023 - 03:29 PM
What is AstroHopper?
It is free and open-source application for sky navigation that utilizes smart phone sensors to find targets in the night sky easily. By attaching a smart phone to the scope you can convert your scope to "push-to" scope with ease.
App: https://artyom-beili...strohopper.html
Manual: https://artyom-beili....io/manual.html
Video Tutorial: https://youtu.be/AtArqBLWWJ8 by Nir Zonshine
Project Sources on Github: https://github.com/a...eilis/skyhopper
Changelog for 1.0.10
  • Added object search box to main screen to improve searching experience
  • Now you can open Wikipedia information page about selected object by pressing "W" button - developed together with Robert Barron.
  • Added Moon to the objects list
  • Fixed parsing of RA/DEC in user object to allow double quote as seconds mark
  • FIxed incorrect escaping of error message in user object parsing
  • Documentation improvement of observation list formatting
(note to moderators - I keep no more than 1 announcement per week rule - it is just recently AstroHopper went viral on youtube so lots of users pop older threads with questions)
  • Dave Mitsky, Bill Jensen, GregB and 23 others like this
#2 adamgali89
adamgali89
  • Loc: Hungary
Posted 06 June 2023 - 06:03 AM
  • tuniscat and artik like this
#3 J.Moore
J.Moore
Posted 06 June 2023 - 09:41 AM
Noted update last night seeing the 'search' button on main screen, cool! Also, I tested the App on my Classic C8 mounted on the original Fork/Wedge mount/tripod which is basically a GEM. Worked as accurate as my ALT/AZ mount but requiring more manual movement in RA/DEC to hit targets.
  • artik likes this
#4 blackhaz
blackhaz
  • Loc: London, England
Posted 06 June 2023 - 02:22 PM
Interesting! I'll definitely give it a go. How would you recommend to attach a smartphone to the OTA? The dovetail-to-smartphone adapters I can find are all 90° perpendicular, so phone's backplate is facing the target. Are you planning to release a 3D-printed accessory for this app? :-)
Edited by blackhaz, 06 June 2023 - 02:26 PM.
#5 artik
artik
  • Loc: Israel
Posted 06 June 2023 - 02:57 PM
Interesting! I'll definitely give it a go. How would you recommend to attach a smartphone to the OTA? The dovetail-to-smartphone adapters I can find are all 90° perpendicular, so phone's backplate is facing the target.  :-)
Note you don't face backplate to stars. Phone need to be parallel to OTA as showin in quick start manual.
Simplest velcro + phone cover. Or even a cello-tape.
Actually there is an accessory, watch here: https://youtu.be/6-_58mSGz1Q?t=253
(It isn't created by me)
Edited by artik, 06 June 2023 - 02:57 PM.
#6 PEterW
PEterW
  • Loc: SW London, UK
Posted 17 June 2023 - 03:04 AM
What sort of accuracy can you get, somewhat surprised the metal tube doesn’t cause too much trouble, but I am sure the phone can handle some local interference and that’s what the calibrate function also helps with. Going to give it a try.
Peter
#7 artik
artik
  • Loc: Israel
Posted 17 June 2023 - 03:36 AM
Peter
Because compass is used only for initial direction. And even in that case it isn't really needed since you can adjust initial direction manually.
After the alignment gyros are used and they aren't affected by magnetic interference
  • Another_Dave likes this
#8 g3cwi
g3cwi
Posted 31 August 2023 - 07:18 AM
Brilliant app thanks. Suction cups arrived today so looking forward to trying In tonight on my 200p
  • LU1AR, artik and Astro_In_Tampa like this
#9 Another_Dave
Another_Dave
  • Loc: Australia
Posted 05 September 2023 - 11:42 PM
Personal real-world experience with it ...
Phone compasses can be affected by local metal, electrical fields, magnets. I had tried a magnetic case for attaching to OTA and that was not the best choice. I now use a cheap second phone case and self adhesive velcro patches. Yes, a steel OTA does affect the compass a bit with my Pixel 7. I also have HV power lines in the vicinity making the compass a bit inconsistent in some directions. But ... AstroHopper only uses the compass to try to get you into the ballpark for your first alignment and, worst come to worst and it's way off, you can scroll to the star for alignment anyway.
I find it best to re-align to the brightest star in the nearest constellation when I move from one part of the sky to the other. Then you can work in and around that constellation with good accuracy. Once the alignment process becomes familiar, you can re-align in mere seconds so this works very well and is no issue.
Give it's free, it's an amazing tool for the low budget astronomer. And it keeps getting better. I commend Artyom on his work with this app.
  • jtomney, isolli, bklynstargazer and 1 other like this
#10 mikee1
mikee1
  • Loc: Southern Ca.
Posted 26 September 2023 - 10:36 AM
So, how does one go about getting AstroHopper, it’s not in the App Store?
I found this on you tube, it looks Amazing, but it does not exist?
https://youtu.be/6-_...9Tn2QT5flDwYhs7
thanks,
mike
#11 artik
artik
  • Loc: Israel
Posted 26 September 2023 - 01:04 PM
You probably didn't watch the video. It is web app. You don't need app or play store to access or install it
Just follow the link
Edited by artik, 26 September 2023 - 01:05 PM.
  • Dave Mitsky, doctordub, davelpg and 1 other like this
#12 Astro_In_Tampa
Astro_In_Tampa
  • Loc: Tampa, Florida
Posted 22 October 2023 - 09:55 PM
OMG... What an amazing program!! Thank you soooooooooooo much!! I loaded it up on an old IPhone 11 that I had collecting dust in a drawer, and I used two small squares of Velcro to attach it to the OTA. Turns out the IPhone compass was wildly off, so I had to use the manual alignment option to align the phone. That was a piece of cake. Once I had it aligned, I was star hopping all over the place! It wasn't perfect alignment, but I think that was more operator error rather than the program. As someone brand new to the hobby, and for my first time using it, I'd say this program is AMAZING! I would highly recommend it to newbies, and even for the intermediate guys. Much has been said in these threads about the need to learn the sky on your own. I happen to agree! I've had my AD12 now for a whole week, and with the aid of first Stellarium and now Star Hopper, I can now look at the sky and pick out various targets without the need to refer to either program. So I think they are great tools to help teach people like me where things are in the sky.
Thank you again for creating this amazing program!!
  • cahanc, rocketsteve, artik and 2 others like this
#13 Dave Mitsky
Dave Mitsky
Posted 25 October 2023 - 10:42 PM
I've been using AstroHopper for a couple of months now with one of my Dobs at my red-zone home and a club telescope at the Naylor Observatory and have been getting better results with each session.
  • cahanc, davelpg, artik and 1 other like this
#14 brenski
brenski
Posted 08 November 2023 - 04:42 AM
Looks like this could be really useful, however, I'm having problems installing it
In order to install the application, open the URL https://artyom-beili...strohopper.html and install it:
– Android/Chrome – tap on “…” near the URL, and select “Install App” or “Add to Home Screen”
not seeing this - all i get is "add to home screen"
is it not possible to install as standalone app?
#15 artik
artik
  • Loc: Israel
Posted 08 November 2023 - 07:59 AM
And this is what you need - you'll have an icon on "desktop" of AstroHopper and it would behave like an ordinary app.
  • Starsareus, brenski, Another_Dave and 1 other like this
#16 brenski
brenski
Posted 08 November 2023 - 02:06 PM
thanks
  • adamgali89 likes this
#17 Padraic
Padraic
  • Loc: AZ
Posted 08 January 2024 - 11:48 AM
Dear Artik,
     Thanks for the app for me as newbie. Watch the Youtube and found you.
Padraic
Skywatcher Flex 250P DOB
Celestron C6 w ASI plus and ASI533MC Pro
  • artik likes this
#18 luna0363
luna0363
Posted 21 January 2024 - 07:44 AM
hallo
can i use astrohopper on a truss dobson
best regards
  • thosan likes this
#19 artik
artik
  • Loc: Israel
Posted 21 January 2024 - 08:25 AM
hallo
best regards
Yes. Why not? Just connect the phone at the ring with finders or to a truss tubes
  • areyoukiddingme likes this
#20 luna0363
luna0363
Posted 21 January 2024 - 01:28 PM
hallo
thanks for the anserw
find astrohopper objekts like jones 1 or ctb 1
i use a self made  18"dobson
best regards
#21 doctordub
doctordub
  • Loc: New Rochelle, New York
Posted 26 February 2024 - 08:52 PM
Thanks for excellent program Artik. bow.gif bow.gif bow.gif bow.gif bow.gif bow.gif
CS
Jonathan
  • davelpg, artik and Sternig like this
#22 areyoukiddingme
areyoukiddingme
Posted 29 February 2024 - 05:13 PM
Will it work with a ball scope (Portaball)? In that case, motions depart from orthogonal. . .
#23 artik
artik
  • Loc: Israel
Posted 29 February 2024 - 05:56 PM
Good question.
I don't really know. Try it. I assume keeping the phone in upright position is helpful
#24 whaleman
whaleman
  • Loc: MI
Posted 15 April 2024 - 10:05 AM
Thank you for the app! It is impressive. Is there a way to search for comet 12P?
#25 artik
artik
  • Loc: Israel
Posted 15 April 2024 - 03:42 PM
You can go to stellarium or whatever app you want and extract RA/DE coordinates for the observation time.
And just add it as a user object. That what I did so far for most comets and it worked without issues
  • MichaelJB likes this
